The Aquamino gets interior, 59 ElCamino
Discussion in 'The Hokey Ass Message Board' started by flt-blk, May 15, 2012.
  1. flt-blk
    flt-blk
    from IL
    The replacement pull handle is a new 64 Impala unit with a chrome plastic base and new pad/foam on top from Ciadella.
    the chrome plating is nice, but the plastic underneath is rough. It looks like the injection molds have seen better days. However I'm not going for show points so I am happy.
    I did have to drill new holes in the door for the back mount, and poke new holes in the fresh door panels (I measured 4 times before I did it).
  2. Hellfish
    Hellfish
    I used vinyl windlace on my 59 and it didn't wrinkle as much as I thought. You can ceck it out on Sunday if you're going to be at the BBQ. I also did the headliner myself. It's pretty easy, especially if you read all the threads I did. :) Do you have the tack strips? I got them locally. Also, I have a can of really good spray headliner adhesive that you're welcome to use
  3. flt-blk
    flt-blk
    from IL
    Unfourtunatley I'm not going to make the Rust Revival or the CzarBQ. Road tripping to PA for the Jalopy Showdown this weekend. Although I would like to look at the rest of your interior closer, before I finish up mine.... you probably have a few lessons learned to share with me.
    Ciadella has already ordered the different cloth material to make the new windlace so that should help make that an easy project.
    My new tack strip came in yesterday, I ordered it with all the other interior stuff in my package deal
    Where did you use the adhesive? Everything on the Elcamino looks like it attatches to either a tack strip or the saw tooth tucking bar thing over the windows. Might be a coupe thing Vs my ElCamino, it's like upholstry light, since there is less of it.
  4. redlinetoys
    redlinetoys
    from Midwest
    Wow! My initial thoughts were "Too bad the dragster had to go...", but after seeing that interior, I say "NICE WORK!!"
    It looks awesome. After finishing that robot, I think I would have had to make a wall hanger out of it and build another one for the car! Great idea!
  5. flt-blk
    flt-blk
    from IL
    When I first got it pieced together and walked into the house Cariann asked why I made an Iron Man Mask. I still prefer Screaming Robot AAAAaaaaaaaa
  6. belair
    belair
  7. Hellfish
    Hellfish
    I ***ume the elky is similar to the BelAir. Mine had a really thin cardboard tack strip (or what was left of one) on the header bow (above the windshield). It couldn't have been used for much more than holding the headliner in place while the glue dried at the factory, so I didn't bother replacing it. I sprayed the glue on the header bow, and on the headliner, let it get tacky, then stuck it together. It stays tacky for awhile, so you can reposition the material, but it holds really well, even when the fabric is stretched taut. I want to say there was one other place, but the sides were held by saw-tooth things, or a cardboard thing at the back. I used a regular old stapler to attach the material to the tack strip.
    If you can wait until after the Heads Up, I can probably give you a hand. I'll also be at the Blacktop Baron's Road Block on 6/2 and you can check out the Bel Air there.
  8. El59Camino
    El59Camino
    from Finland
    Great 59. Good ideas for own project. Should do all the same things. And the cup holder rules!
  9. gwr1800
    gwr1800
    Add a couple of LEDs to the base of your "cup holders" with clear glue to the red plastic and your cup holds could have a nice red glow at night.....
    Just a thought....
  10. ytt49
    ytt49
    from socal
    very clean car. I love the cup holder/shifter cover.
  11. PBRmeASAP
    PBRmeASAP
    WOW, dude, Looking good!
  12. 60widewhitez
    60widewhitez
    makes me want to finish the 60's interior. I gotta get that turnpike first!
  13. Bruce A Lyke
    Bruce A Lyke
    Really like the seat as well as the rest of the build.
    Just wondering, did you also get the seat cover from same place as the rest of the interior stuff?
  14. zman
    zman
    from Garner, NC
    Vey nicely done, really digging the console.
  15. Cody Walls
    Cody Walls
    Like i said at the showdown to you i love your car , we only spoke for a couple of minutes and i told you a little about my 59 wagon , the interior looks amazing , i to have been working with gina from ciadella on my interior for my wagon .we've been back and forth for about 2 months now and got everything finally fugared out , they are great bunch of people .. i wish i could have chatted with your longer saturday , but aneyways keep up the great work . and i look forward to seeing your elky in the near future.
  16. flt-blk
    flt-blk
    from IL
    I got the seat cover several years ago from EZ-Boy interior..
    Seems to be hit and miss with them, I was lucky enough to have a hit, but many others have had a lot of troubles.
  17. Nads
    Nads
    from Hypocrisy
    It seems that things with Z in the name are always questionable, Zardoz, ****ty move, Bumper BoyZ, ****ty chrome, etc.
  18. zman
    zman
    from Garner, NC
    Hey hey, not all of them :p
  19. Man oh man Tyler, have you ever done anything half-***ed in your life? That looks awesome.
  20. flt-blk
    flt-blk
    from IL
    That's funny, My last name starts with a Z, and I have been called questionable more than once. :D
  21. flt-blk
    flt-blk
    from IL
    After a mishap with the post office, I finally got my samples of welting material. I think the darkest one matches the carpet pretty well, and it blends into the paint color.
    I got some 1/4" staples and will pick up a heat gun sometime next week. Can't wait to get after the headliner and ****on up this project.
    Then I have a leaky power brake booster to deal with. :rolleyes:
  22. flt-blk
    flt-blk
    from IL
    I finally got all the pieces to do the welting and headliner.
    Pretty straight forward.
    Install the new tack strip around the door openings using the tabs that are part of the pinch weld. A few of them needed some m***aging but that's normal.
    [​IMG] [​IMG]
    In this picture you can see where I had to screw the new tack strip into the roof. Originally it was stapled and I had no way to do that. I drilled a countersunk hole into the tack strip and marked the roof, then I drilled a hole in the roof. the screws sit flush so the garnish molding does not hit them.
    If I was doing it over I would have put all the tack strip in before the gl***. The section over the dash for the front of the headliner was a *****.
  23. flt-blk
    flt-blk
    from IL
    I was dreading the headliner.
    my prep work included cleaning all the top bows to ensure they were not rusty and they would slide into the listing.
    Everything had to come out, all the garnish moldings, visors, etc.
    It was a nice hot weekend so I set it out in the sun to warm up while I finished up the welting.
    And the ugly Before picture.
    There is another hour and a half getting that stupid dome light wire up the A pillar, and I still need a new socket before I can get it to work.
  24. flt-blk
    flt-blk
    from IL
  25. flt-blk
    flt-blk
    from IL
    I started in the back middle and slowly pulled the headliner taught and stapled it into the tack strip. This involved several p***es and some work with a heat gun.
    When I got to the sides over the door, there is a serrated metal strip that grabs the material after you tuck it underheath. I thought a putty knife would do the trick but it turns out it is too thin and sharp, so I had to make my own thick version with a bull nose.
    [​IMG] [​IMG]
    So with the Tucking tool made I started to tuck it all under the edge and pull it straight.
    I still have quite a bit of work to do.
    Once again I have a new found respect for upholstery, I'm not sure I would want to tackle this on a full size car.
  26. flt-blk
    flt-blk
    from IL
    I need to take some more pictures of the mostly finished product. The corners turned out OK, and the garnish moldings really cleaned up the edges.
    It looks a lot better than the old yellow ****py headliner that was in it before, and much better than no headliner at all.
    I need to do some touch up work this week, then it's off to the Hunnert Car Heads Up for a little drag race action, I wonder if the new interior will make me go faster????
  27. goatboy
    goatboy
    from kansas
    very nice job, love the elcos
  28. Hellfish
    Hellfish
    It won't make you go any faster, but you'll look a lot better when you get there. :)
    Nice work!
  29. flt-blk
    flt-blk
    from IL
    But Joe, I already look good. :) :)
    No really, I was hoping it will help me beat PBRmeASAP with his new Blown Chev tub.
    We never got the rematch last year and he sold his truck.
