YES SIR May I have another.....The May 2012 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, May 1, 2012.
  1. RichFox
    RichFox
    Flash babbitt steel backed main bearings is one reason. Full pressure oil to rods and mains another. The deep block secure location of the main caps a third. The first car in the Hop Up Magazine 100mph club was PB powered
  2. That is a nice looking engine. My friend has a stock 29 Plymouth with a 4 Banger. I think it is 174 cubic inch engine. The car is a two door sedan and is heavy. My stock model "A" seems to have a lot more horsepower.
    I like working on his Plymouth. It has a vacuum canister fuel pump that works off the engine oil pump. The gas tank looks like a 32 Ford. It took a while to get the vacuum fuel pump to work. He bought a bunch of them. They were pretty rusty but with combination of all of them we got one that works. He has built, sold and bought a lot of high dollar cars and I think he has enjoyed this one the most. It is something he can work on . No computers, fractional size bolts and nuts, and just plain good engineering makes it a joy.
  3. Hapydz
    Hapydz
    Oh, great ! Now you tell me ...lol
    Ron
  4. RichFox
    RichFox
    I would have had my Plymouth running two or three times for the time and $$$ I have put in the Dodge Bros. But I really, really thought the Morton & Brett head needed to be out and running where people could see it.
  5. Kume
    Kume
    Model A or B motor into a standard T ch***is
    I apologize for interrupting but this is my first Banger thread post and despite relentless key word searching I have found little info on this topic. I figure if anybody can answer my questions it is the incredible knowledge base on this thread.
    Is this feasible or too much work. I have a standard 26 roadster and want to ditch the crazy T donkey for either an A or B motor and box. Last resort is to graft an A ch***is but am trying to build a trad gowjob based on T bones. I suspect there are threads on this topic that I haven't been able to find.
    Would the main problem be clutch and brake pedal location and mechanical brake linkages.
    Can any one steer me to relevant threads or interweb sites. I would be very grateful for any guidance.
    Kume
  6. RobC
    RobC
    from Australia
  7. I did start this years ago but abandoned using the T ch***is. Made it worse for myself by using RHD running gear...
    I was trying to keep the crankline in the same place on a full fendered tourer.
    Here's a couple of pictures someone sent me of an install they did.
  8. youngster
    youngster
    from Minnesota
    Kume,
    You could use the front mount from a '34 pick-up and fab something like a float-a-motor side mounts. An other option would be to fab a T type mount to "hang" the motor from the top of the rail.
    The clutch pedal will need to be reshaped a bit to clear the frame rail.
    On my '21 on a narrowed A frame, this is how I set up the mech. brakes;
    I simply shortened each side of the bellcrank and added 1/4" plates and gussets.
    Ron
  9. Bigcheese327
    Bigcheese327
    HAMBster GARY? has an A-engined, T-framed gow.
    And -Brent- has a similar setup with his A-engined, TT-framed roadster.
  10. Kume
    Kume
  11. Kume
    Kume
    Thanks Monkey Biker
    That looks like a snug fit - is that the stock front cross member you have mounted the front engine mount to? why did the RHD make it more difficult.??
    Kume
  12. Kume
    Kume
    Thanks Ron
    Thats encouraging - I thought about the rear engine mounts hung off the rails like a T - seems like the simplest solution. Brakes dont seem to be too much of an issue.
    Kume
  13. Kume
    Kume
    Thanks BigCheese
    Gary's roadster is one of my all time favorites - looks like he has front brakes so ***ume A axle?. Not familiar with the bottom T but love the exposed mechanical brake rods. There is no stopping me know!
  14. youngster
    youngster
    from Minnesota
    Mind if I add mine to the lot?
  15. Flat Ernie
    Flat Ernie
    Tech Editor
    Was there an April Banger meet? I've been out of town and trying to update the Tech links - got March & May, but no Apr with a quick search.....
  16. 97
    97
  17. Kume
    Kume
    After a day spent trawling the HAMB following leads from above I think I have found everything I need. I new it would all be in here somewhere.
    Thanks to great info and build threads for Brent, Gary and Youngster's A/Ts - absolutely inspirational stuff.
    cheers
    Kume
  18. I was looking at mounting a second crossmember to pick up the A front engine mount. There's the snout of a T sump mounted to the original front crossmember to help line things up.
    The body has eventually made it's way onto this my "1927 Mercury" as christened by Mr. Big Cheese...
    After messing around porting a B engine that turned out to be cracked I've been offered a hot diamond A engine which if funds allow will find it's way in there.
  19. Hapydz
    Hapydz
    Anyone know what kind of psi the "B" fuel pump puts out ?
    Ron
  20. Hapydz
    Hapydz
    A little slow this morning, I found it 1 1/2 to 3 psi.
    Ron
  21. Bigcheese327
    Bigcheese327
    Ah, you liked that, did you? :)
    Such a great-looking car!
  22. Bluto
    Bluto
    Ron please get a gauge..... vacuum/pressure
    Your gonna need a Vacuum Gauge to adjust those carbs
  23. Hapydz
    Hapydz
    Thanks Jim, will do..
    Ron
  24. Bluto
    Bluto
  25. Kume
    Kume
    ["I was looking at mounting a second crossmember to pick up the A front engine mount. There's the snout of a T sump mounted to the original front crossmember to help line things up."]
    Thanks Monkey
    It now makes sense. Riveting a second cross member in seems a good option for me. allows some flexibility in working out rear axle and torque tube position.
    By the way - love your flathead T - there is something incongruous about seeing a bright shiny yellow or red Ford hotrod in the English landscape but your T fits in like some kind of renegade medieval knight. love it!
    Kume
  26. denis4x4
    denis4x4
    from Colorado
    Check out the coverage of the Speedster Reunion in the August issue of R&C.
  27. Flat Ernie
    Flat Ernie
    Tech Editor
  28. Hapydz
    Hapydz
    Jim; This is a great link even for the realativly simple banger motors. I feel smarter already ;). Well, maybe not smarter but I feel that I'm on the right track thanks to you. Really looking forward to knowing rather than guessing :)
    Thanks Jim !
  29. Crazydaddyo
    Crazydaddyo
  30. Bigcheese327
    Bigcheese327
