I have an allen system III, I would like some info on it and possibly the HEI lead for the arm for the scope. And if possible, where to get the cal gas. Thanks -Brant
I moved all my stuff here to Poland but have been afraid to plug it into a converter This is my 1941 Allen It has a magic eye tube I'm a bit afraid of 50hz Sent you mail
I have an old sun from the 50s, i know the tail pipe tester hose is bad, and one instrument is balled up....i'll check it....
I'm fixing up a MD-1 and a SDT I would like to find the original owners manuals and a manometer set up for my MD-1 since it is missing and would like to restore it. I could use a knob and new battery covers if available. They made a rubber mat for the car battery too that I don't have. I need to upgrade the capacitors and diode kit if you have them. I will need to eventually be able to test electronic distributors. Can you tell me if there is a way to date these two machines accurately? The MD-1 has a tune up scroll that shows 1955 cars as the latest so I'm guessing 1954 or 1955. I don't know on the SDT except it also takes 2 Dcell batteries. Can the serial number tell the exact year? I also need two of the D cell battery sleeves as mine are corroded from acid leaking batteries. Thank You, Kevin Kline Fullraceflathead
hi rmasters3 can you supply a user and repair manual for an Allen E1415HD dizzy machine my email is emma351@dodo.com.au
It doesn't look like Bob Masters has been on this site for about 1 1/2 years, you might contact him at http://www.distributortester.com/
