Customs My shoebox chop
Discussion in 'The Hokey Ass Message Board' started by Stefan T, Oct 21, 2009.
  1. JAWS
    JAWS
    Atta boy Stefan!....
  2. Stefan T
    Stefan T
    from Sweden
    Thanks for the coment
    The timing gear cover is fixed for use of a Chevy distubrator
    but it have still some green color so i have to fix it
    I polish it and ***emble it to the flathead and the oil pump is mounted to
    one more pic on the oil pump with the oil pressure connection out in the bottom to the filter
    The pan is now on place too
    /Stefan
  3. Ray C's son
    Ray C's son
    Man, that's looking sweet, Stefan.
    I really like your solutions to the challenges you have faced. Really creative.
    Kevin
  4. JAWS
    JAWS
    Stefan, are you going to fire this on a stand before you install it?
  5. oldman2
    oldman2
    Looking good, Stefan, looking good.....Jim
  6. Stefan T
    Stefan T
    from Sweden
    I belve not to fire it up in the stand
    In that case need the radiator and thats so easy to have in the stand
    /Stefan
  7. Stefan T
    Stefan T
    from Sweden
    I have build little more on the flathead
    I shall have studs to the heads so now are they on place
    the blower mainfold must be ***embe to the motor before the heads
    I have made a plug from a M12 bolt to the fuel pump push rod hole
    My sisters son Andreas help me with blower mainfold.
    the manifold is one place
    the navarro heads is on the flathead
    Water pumps is bolted to the engine
    The heads shall be torqued.
    I seen that the alu head shall have diffrent torquy settings than the cast heads
    Is there anny how knows how mutch is the right to my navarro heads?
    /Stefan
  8. oldman2
    oldman2
    Can't help with the heads, but the engine looks amazing....Jim
  9. BrerHair
    BrerHair
  10. cuznbrucie
    cuznbrucie
    Torque spec on aluminum heads is 40 lbs, Stefan.......don't overdo it......and there is an order to tightening them down......you start in the center and work your way out...
    There's diagrams in a lot of books on the order of tightening the head nuts...
    CB
  11. Boy that's pretty
  12. harley jim
    harley jim
    nice work Stephan
  13. draider
    draider
    from Texas
    Looking good. Keep the updates coming!
  14. Stefan T
    Stefan T
    from Sweden
  15. JAWS
    JAWS
    I would trust anything Max or his brother says. They definitely know thier stuff. :D
    Max is crazy like you!
  16. yetiskustoms
    yetiskustoms
    interesting approch, keep it up
  17. ftw666sgv
    ftw666sgv
    damn!!! thats some nice *** work!!!
  18. Stefan T
    Stefan T
    from Sweden
    Thanks for all that like my shoebox build and flathead build too
    Little more parts on the blown ford flathead
    The blower is on for test
    The blower is a GMC 3-71
    I must line up all the pullys
    so it will some shims and the crankshaft wheel shall i make little shorter
    /Stefan
  19. Finnrodder
    Finnrodder
    from Finland
    Looks good,Stefan!
  20. Stefan T
    Stefan T
    from Sweden
    thanks for the comment
    i have worked a loot with my Oldsmobile so it have not been so mutch shoebox work
    The engine is in the car but the new th 2004r are left to ***emble in the olds
    but i have line up the pullys
    /Stefan
  21. Swede64
    Swede64
    Great work on the Shoebox and as a fellow Olds owner i really
    really like that L69 set up.
  22. Stefan T
    Stefan T
    from Sweden
    Thank for the coment
    I have put in a extra wheel to get more angel around the crank pully
    So it will be better posibitys to drive the blower on the 8ba flathead
    a last pic before i dis***emble some parts from the motor before painting it.
    /Stefan
  23. oldman2
    oldman2
    Stefan, that engine is looking sweet.....Jim
  24. tedley
    tedley
    from canada
    Wow that's nice. how much is it underdrivin
  25. Stefan T
    Stefan T
    from Sweden
    The blower is approx 8% overdrive if i rember right
    The picture make the diffrece wrong
    so the blower pully is smaller than the crank pully
  26. Shane Spencer
    Shane Spencer
    awesome build. awesome work and style, diggin the vw too. good luck and keep it goin
  27. Mats W
    Mats W
    A rescent shot of the '57 V-Dub:
    Stefan's Shoebox build in the background
  28. Stefan T
    Stefan T
    from Sweden
    Thanks for all coments
    I have worked little on my flathead
    I have ground paint it so next thing will to paint it
    /Stefan
  29. farmer12
    farmer12
    Love the engine Stefan, looking great!
  30. johnod
    johnod
    Your engine looks great, been enjoying this thread a lot, thanks.
    Is that a single serpentine belt runing everything?
