1929 Ford Coupe Sheetmetal Work
Discussion in 'The Hokey Ass Message Board' started by Flop, Mar 31, 2012.
  1. TexasSpeed
    TexasSpeed
    from Texas
    X2. Especially when the bolts are rusted to the quarters.
  2. Flop
    Flop
    well up front to a rotten door pillar
    a little brace so i can fix the bracing
    bent this up made the step with a bead roller and all welded up ready to get covered in sheet metal!!
  3. stewscoupe1929
    stewscoupe1929
    Looking awesome Flop!!! I aways admire your and B***'s sheetmetal work!! The hardest thing for me is taking my time on not warping the metal when welding 18Ga or so sheetmetal up! but im getting better about be patient and working the metal to get a nice blended look!
    Whats the secret?
    Line the panels up perfect... spot weld, grind a little, hammer and dolly Then repeat till your panels are slick?. Hint me in! Keep up the good work man!! And im jelous you got a A roadster and i dont!
  4. wandi harry
    wandi harry
    Flop, its blokes like you that make the HAMB
    Not only do you do great work but you take the time to post photos etc
    that gives us dummies some insight of how to do things.
    Thanks
    Harry
  5. Flop
    Flop
    thanks stews!! i dont know really i tig weld everything . tight gaps . easy on the grinding discs so you dont leave deep cuts in the metal . i only wled about 3/4 of an inch at a time and finish the panel as i go. thats a customers roadster well there are 2 . i have a 30 coupe that im gonna start soon
    thanks wandi!!
    well got the quarter patched and the wheel well a quarter of the way in
    i also wonder why they make the patches so horrible ? i mean come on almost a quarter inch short isnt from die wear!!
  6. big creep
    big creep
    wow flop great work as usual!
  7. TexasSpeed
    TexasSpeed
    from Texas
    They like making things interesting for the hobbyist. ;)
    Do you know what company your front subrail "feet" are from? The subrail patch panels from behind the cowl.. I wonder if they're the same as mine. I have a set here but I'm not sure if the work to make them match the original subrails are more or less of the patchwork needed to fix the ones I have on there now. Both seem to have about the same amount of work required to go either way.
    Maybe I'll just take what I need from the subrail patches and put them on my original stuff.
  8. Roadsir
    Roadsir
    Nice work, on your external sheet metal patching can you share your process, are you filing, shrink discing, then using a series of grits to metal finish?
    Also what type of tig are you using?
    Thanks for posting.
  9. scrap metal 48
    scrap metal 48
    I wish I could do that.. Very nice work......
  10. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    I bet you couldn't put my '32 5w together for free....I betcha wink wink...
    So very nice dude.
  11. the metalsurgeon
    the metalsurgeon
    from Denver
  12. Flop
    Flop
    thanks big creep!!
    tex***peed i think only one company is going to make those and for some reason i think its brookville .
    cant give all the secrets away nuroadsir!! grind with a 6 inch 36 grit disc. finish in 80 by hand . i use miller machines.
    thanks s**** metal!
    mr james i could give it a shot . but it would probably sit for a long time hahah .
    thanks metalsurgeon!!!
    well got the wheel well and quarter done today .
    it was a task at hand . the owner removed to much metal so i had to recreate the curved reveal out of weld where the patch meets the og metal
    and heres a few holes of what was left after the patch was in
    and this is it all finished up
  13. Flop
    Flop
    well took a run to snyders today picked up the rear patch for Mile's coupe as well as a truck full of other things
    heres the problem .
    which in-turn ****ed in the trunk gap
    a little br*** and a double panel!!
    tacked in
    about 75% done
    no real complaints with the panel either a little tweaking here and there but no major surgery to it yet !
  14. Flop
    Flop
    one of the biggest PAINS in putting together a model a is this panel.
    its a horrible fit from the get go . the "new bracing" is dreadful .
    notice the giant twist
    the orig panel wasnt the best . pinholes everywhere . i transferred the orig bracing to the new skin . it fit alot better after that
  15. Ray C's son
    Ray C's son
    Man, That's some beautiful work as always, Flop. Did I read right and this is going to be your car?
    KRH
  16. Gremlinguy
    Gremlinguy
    Looks great Flop.
  17. Flop
    Flop
    Thanks! I have a 30 coupe for myself thats in horrible shape .
    http://www.jalopyjournal.com/forum/showthread.php?t=677367
    thanks gremlin.
    got the back panel all tied together today and primed since it would be a bear to do with it all together .
    tomorrow I get to tackle this which i doubt is going to be any fun either .
  18. Flop
    Flop
    shop organizing day . cars outside
    moving right along now!!
  19. koolkemp
    koolkemp
    Wow thats great Flop ! You having to much fun !!
  20. Flop
    Flop
    thanks koolkemp!! im having a blast actually. never thought it would come to this .
    well the repop curved inner panel come with this fabulous trunk latch installed..
    very happy Miles saved the one from his coupe.
    finally got everything lined up and fitting as it should
    the new parts with the old latch installed. works great!!
  21. baspinall
    baspinall
    from SE PA
    Love the visual tour of a metal working genius! Keep it coming.
  22. willie57
    willie57
    from wisconsin
    looks great nice work
  23. Flop
    Flop
    thanks guys!!
    heres the quarter patch welded in . again about an eighth inch short .
  24. coopsdaddy
    coopsdaddy
    from oklahoma
    great work,thanks for posting
    no **** on the patch panel fit,whos making the best 30 coupe qtr patches?
  25. jfg455
    jfg455
    from NH
    You have to remember there is a bunch of variable with any replacement panel. Some are on the manufacturer of the panel. loose dies, sloppy R&D work etc. But you also have to realize if you take 5 panels from 5 different Model A's they will all be a little different. Quality control was not as tight then as it is today just by the technology level they were dealing with. I remember working in My Dad's MG resto shop and every single piece that was replaced, repaired or added had to be fit to the car we were building regardless of if it was OEM or aftermarket. Just my $.02. Nice work on the build too!
  26. 117harv
    117harv
    Never disappointed when i open up a Flop thread, GOOD stuff!
  27. Flop
    Flop
    they all seem the same coops daddy
    this is my first 29 . i am used to working on the 30 /31s
    good info jfg455
    thanks harv117 . killer work on those 36 bones you did !!
    heres a time lapse i did of 2 hours worth of work on the wheel well jammed into 45 seconds
  28. greaser
    greaser
    Man, you're really movin!
    Great work by the way!
  29. titus
    titus
    Looking good, yeah those repop rear panels are POS's!
    JEFF
