upper air bagmount for 54 chev
Discussion in 'The Hokey Ass Message Board' started by eugene vik, May 27, 2012.
  1. anyone got ideas and pics ?
    to put a decent top mount in and get it lined up properly 1954 150 2 door with a little rust :mad: but not totalled
    this do it yourself stuff is a lot of work:(
    but no money gives you a lot of new skills!!:eek:
  2. mrconcdid
    mrconcdid
    from Florida
    Search "airbag chevy stock front end" there's several good threads on it.
    Godspeed
    MrC
  3. Lone Star Mopar
    Lone Star Mopar
    Hamber Rusty Pipes did a tech thread on bagging a stock frontend.
  4. doing the rear
    too much luggage with OL and spare parts for road trips
  5. yetiskustoms
    yetiskustoms
    The rear is the easy part! Almost any rear bag job can cross over to your ride. Are you still running a torque tube?
  6. no torque tube got olds wagon rear
    with stock springs
    looks like i is gonna have to run the pipes under the axle
    and figure out how to weld a crosmember where the bend is in the frame
    and weld it in place with the body on with my diabetic hands, burns dont heal
    looked at your pics nice job
  7. kdrodworks316
    kdrodworks316
    from idaho
    Check out my build thread on my 54 chev, I followed rustypipes thread and mine went together very smooth and works great. Good luck on your build
  8. englands54
    englands54
  9. englands54
    englands54
    sorry here is one
      20.2 KB
  10. Eugene, check out Summit, etc. for bolt-in air bag helper kits for drag racing. Guys have been bolting air bags on rear axles to help the launch a lot longer than they have been a mini truck fad...
  11. mrconcdid
    mrconcdid
    from Florida
    Yes the rear is easy, look at my thread, I didnt cut the floor, but I also didnt c-notch the frame either. build a bridge between the frame rails and install bags either infront or on top of the rear end, if you place the bag behind the axle you will need to relocate/ or get a different gas tank.
    Godspeed
    MrC.
  12. THE BRONSON
    THE BRONSON
    Damn good tech
  13. Gambino_Kustoms
    Gambino_Kustoms
    Alliance Vendor
  14. looked at alexes links great stuff thanks
    mr concded looks like that will be the way i will have to investigate, got lots of leftover parts as this stuff never fits so will have to try to get er done this car is a spare driver so i dont want to cut any tin and we have cold weather here
    i dont need a notch but want to lift this when needed i did the same on my 60 buick and it works well just with the rear
    i have a mustang front and have a air bag kit that would fit but i may run the lines and controlls but dont think i will put it in right away
    the front sits way low already about 4 in under the crossmember or less
    i am gonna put working lakes pipes on this and plan to put them under the rocker panel in height[i think] so thats why i would like to be able to raise this up for clearance
  15. mrconcdid
    mrconcdid
    from Florida
    let me know if I can help, look at my thread for pics of both front and rear setups, there the same thing you are doing.
    Godspeed
    MrC.
