1958 mer M.E.L motor with a edelbrock ford fe 6x2?
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, May 28, 2012.
  1. 56 ford custom
    56 ford custom
    from Socal
    Will the edelbrock ford fe 6x2 bolt up for a 58 mercury M.EL. ?
  2. austlinc
    austlinc
    from Australia
    No, there are specific MEL Edelbrock manifolds, I beleive the part number is LM6 for that one. They come up on ebay from time to time.
    Cheers Angelo
  3. 56 ford custom
    56 ford custom
    from Socal
    Thanks for the info. Guess im back in the hunt for an fe motor.
  4. Oldmics
    Oldmics
    NO
    F.E. series is a different critter than M.E.L. family.
    M.E.L. speed parts are a challange to find.
    Good luck,Oldmics
  5. FrozenMerc
    FrozenMerc
    The only thing that interchanges between the 2 motors is valve rockers and lifters. Everything else is different.
    For the record.
    MEL 3x2:
    FE 3x2:
  6. There are more tiems than the rockers and lifters that will interchange with the FE engine, but it depends upon the year of the MEL engine.
  7. 56 ford custom
    56 ford custom
    from Socal
    That first pic wouldnt that be Y block?
  8. iamben
    iamben
  9. 56 ford custom
    56 ford custom
    from Socal
    Is that yours?
  10. iamben
    iamben
    I officially stole that one from the web. MEL's are an engine onto their own and like someone else said the speed parts are hard to find.
  11. 56 ford custom
    56 ford custom
    from Socal
    Oh ok. Just checking. Yes they are scarce.
  12. austlinc
    austlinc
    from Australia
  13. 56 ford custom
    56 ford custom
    from Socal
    I was just curious to what interchanges. I have the fe intake and valve covers. Now just need a good running motor.
  14. rld14
    rld14
    Edelbrock made a tri power manifold, it;s the L300
    They are rare, but then again there's not LOTS of people looking for them, they seem to bring $300 or so, maybe a tad more when they show up.
    Watch the MEL site and thelincolnforum.net
    Oh, I figure you have a Mercury, but tri-power won't clear the hood of a 61+ Lincoln.
    There's a factory setup that exists, a complete Mercury Super Marauder setup is worth a few thousand, with the Lincoln air cleaner? Well that air cleaner alone is probably $5,000!
    Oh, while we're talking MELs.....
    1) Replace oil pump and oil pump rod, use a billet FE one, ground, IIRC, .075 off the end of it to make it fit.
    2) Replace timing gears, the OE ones have nylon covered teeth on em for quiet running, said nylon teeth fall off, clog oil pump pickup, terrible things happen.
    3) Remove water pump, CAREFULLY remove the two small head thermostats, see em? Now take them and throw them out.
    4) If you need pistons, get em from Wiseco, plan on spending about a grand but they are the only source I know of for correct ones, FLAT TOP PISTONS WILL KILL YOUR CR! These engines have the combustion chamber in the cylinder, like a Chevy W motor. You NEED dished pistons.
    The good? They have more torque than a locomotive and are incredibly tough.
  15. 56 ford custom
    56 ford custom
    from Socal
    I think there is confusion here. I am running a ford fe with the manifold I posted the pic of.
  16. FrozenMerc
    FrozenMerc
    Yep, I posted that pic incorrectly. It has been changed. :(
  17. Here is a 383 MEL 4engine from a 58 Merc. It is currently in the cl***ifieds.
  18. 56 ford custom
    56 ford custom
    from Socal
    Kiwi, your add is what started this! Haha. I thought I might be able to use my manifold on it bit I was wrong..I also heard there is an adapter?
  19. tombstoneater
    tombstoneater
    from wisconsin
    a edelbrock lm6 just popped up on ebay
  20. Wowcars
    Wowcars
    56 Ford Custom, you can use an FE transmission adapter for the early MEL. Later ones (462ci) have their own bellhousing pattern.
  21. 56 ford custom
    56 ford custom
    from Socal
    Well if the bell is the same...I think I might try to score a mel
  22. Thunderroad312
    Thunderroad312
    The early '58-60 Mel uses a FE bell housing pattern. '61-'66 is different and the late 462 is different still. Only Ford! I'm aFord man through and through but I will never understand their fixation with changing bell housings.
  23. mgtstumpy
    mgtstumpy
    Here goes if anyone is interested in a MEL manifold
  24. Wowcars
    Wowcars
    I'm interested to see what that goes for. I have the same intake but drilled for Rochesters.
  25. 56 ford custom
    56 ford custom
    from Socal
    Pm sent Sir
  26. 56 ford custom
    56 ford custom
    from Socal
    The MEL is too hard to come by I think ill stick with an FE
  27. steve07
    steve07
    Anyone know of a set of headers for the MEL engine that will fit a 58 Merc?
  28. FrozenMerc
    FrozenMerc
  29. Wowcars
    Wowcars
    Steve, one way to go is to get a set of MEL flanges and a set of BBC headers, cut the flange off of the headers and weld the MEL flange on. The port spacing is almost identical. That is if you can figure out a set of BBC headers that will fit in a 58 Merc!
