4 door to convertable??
Discussion in 'The Hokey Ass Message Board' started by oldjeepdog, Feb 3, 2012.
  1. I have enjoyed reading the posts when a 4 door is converted to a 2 door.
    Has anyone ever converted a 4 door to to a two/four door convertable? Any make any model?
  2. [​IMG] i turned my 36 ford four door into a 2 door roadster
  3. Any pictures?
    Would love to see a build thread on this.
  4. James D
    James D
    Look for Boomosbys threads. Thats how to do it right, with bits from a genuine convert. Hacking the top off a four door seldom leads to a good result.
  5. Dave Mc
    Dave Mc
    I took this derelict 33 Fordor and cut the roof off,shortened the rear body/roofline, used the rear part of the original roof and made a rear body panel with a trunk opening,created a trunklid by dissecting,downsizing a 38 Chevy trunklid to fit the opening,etc.etc. in other words I cut it up and transformed the Fordor Sedan into a 33 Fordor Victoria Convertible Sedan ( with a Trunk ) a model not offered by Ford in 33
    Build Thread -> http://www.jalopyjournal.com/forum/showthread.php?t=570915
  6. Remember that many convertibles had thicker frames or additional bracing because there was no longer support from the roof. What make and year are you looking at? Aside from that these conversions usually don't come out very well and the person would have been better off cost wise starting with a convertible. As a final insult it would probably be hard to sell the finished car.
    Charlie Stephens
  7. tubman
    tubman
    A friend of mine did a '64 Impala about 25 years ago. He started out with a pretty nice 2D hdtp and a rusty (but complete) convertible. It turned out real well. I think the key to the deal was having a complete convertible for parts.
  8. Foose did a 53 ford and a 57 chevy on overhauling, Its definitely somting that takes a lot of thought and planing in order to pull it off .
  9. Doctor Detroit
    Doctor Detroit
    I've seen examples of 49-51 Mercurys as a four door with the top cut off and a Carson top added. Depends on what model you are looking at to perform this on. These pictures were probably found elsewhere on the Hamb:
  10. The big thing to remember is a convertible at the least always got a big X shaped brace added to the frame, unless it was something like a 49-54 Pontiac where the frame already has the X - those got thicker material in some places and additional body mounts in others.
    To do it right entails a donor convertible, and a donor coupe or sedan. It really doesn't matter which you begin with, they both get the body taken off, the convertible parts transferred to the good frame and anything missing or too rotty to use fabricated, then the good body goes on this frame and is cut down to the floorpan - depending on how the convertible is rotted, you start at the cowl adding the upper convertible cowl, then doors, then rear quarters with the top tub and supports. It's not a projct for the faint of heart.
    But you can cheat, if you just have an old ****py sedan - make your own frame brace by copying whatever the factory did, if you want to change the doors either get 2-door doors and move the B-post, or cut and weld the doors you have; THEN cut the top off, and if you can find a later model convertible cheap, you can even fit the folding mechanism from that into it. Which is certainly possible to do. I have a complete top for a '72 Skylark and could never give the damn thing away to the point I'm not even sure where it is right now.
  11. Rusty O'Toole
    Rusty O'Toole
    It can be done at several skill levels. Easiest, hacksaw the top off an old sedan and bomb around the beach town all summer then send it to the s**** yard.
    Next level a parade car with the frame and body braced but no top, or a removable lift off top.
    Highest level build a genuine convertible with folding top and wind up windows that fit. If you have the time money and talent to do it right. At this point it would be quicker easier and cheaper to just buy a good convertible.
    If you really want to build a 4 door convertible it be best to start with a 4 door hardtop, half the work is already done. I mean bracing the body and frame, and making the doors and windows fit right.
  12. James D
    James D
    The only thing to add to that is - don´t cut up a four door hardtop - they´re rare and cool! :D
  13. desotot
    desotot
    I turned a 54 olds 4dr to a rag using a 56 buick 2drhdtp donor car and a set of 66 pont top bows.
  14. x-2
  15. desotot
    desotot
    I turned a 4dr 52 pont to a carson top car
  16. desotot
    desotot
    I changed this coupe into a rag, scratch built the top bows, 4" chop on the windshield
  17. Squablow
    Squablow
    Any more pictures of this? I'm amazed how well the '66 convertible top rack worked on there, I'm impressed.
    I'm planning to convert my '55 Dodge 4 door but I have a complete, rotted out '55 Dodge convertible plus a set of extra nice 2 door hardtop doors to do mine with. I did a '72 GTO the same way, using a '69 Buick Skylark convertible as a donor, but that car was a 2 door hardtop to start with, making it easier.
  18. desotot
    desotot
    For some reason I have picked up three sets of those g.m. bows over the years and used them but they are more work because they are designed for curved gl***, it would be easier to use a top frame made for the early sixties and older cars. G.M. stuff is the easiest to work with because the are mostly steel construction where ford uses more cast aluminum. But the real limiting factor I suppose is ones imagination. Although to much imagination can lead you to do things with your time that will interfere with being a couch potatoe.
  19. Tricknology
    Tricknology
    from DETROIT
    imho, when making a 4 door car a convertible ,,KEEP it a 4 door,,and make it like a 1960's lincoln 4 door convert or like a 1940's buick 4 door phaeton
    an old buick 4 door could be made into this
  20. Tricknology
    Tricknology
    from DETROIT
  21. boomosby
    boomosby
  22. John Lafayette
    John Lafayette
    Keep it up and 4 doors won't be cheap anymore!!!!!
  23. Chris Stapley
    Chris Stapley
    Here's my journey so far this past week...... 1956 Dodge Custom Royal.
  24. bills49merc
    bills49merc
    Here are a couple of shots of my 51.The car just came back from the trim shop yesterday.Just waiting on Pauls to finish the smoothed bumpers
  25. bills49merc
    bills49merc
    Sorry here are the pics
  26. mgtstumpy
    mgtstumpy
    What car are we talking about? What about a 30s convertible sedan, they look right. Down here we had 4 door phaetons into the late 30's
  27. Damn that 54 Olds came out nice!
  28. Dog Dish Deluxe
    Dog Dish Deluxe
    from MO.
    I'd love to see pics of 4dr convertibles too. It sometimes makes a car less interesting to turn it into just another 2dr in my opinion.
  29. koolkemp
    koolkemp
    Bumpfor a cool thread!
  30. lockwoodkustoms
    lockwoodkustoms
    Well here is some thought for you guys eventhough it is a real factory convert. :D
