Hot Rods Clarence? He Needs Clearance...
Discussion in 'The Hokey Ass Message Board' started by Ryan, May 30, 2012.
  1. Ryan
    Ryan
    ADMINISTRATOR
  2. chaddilac
    chaddilac
    Cool scoop!!!
  3. BOP-Nut
    BOP-Nut
    Add two inches to the entire top of the hood where it needs it and then let it drop gracefully back to the front and rear. If that makes any sense.
  4. willymakeit
    willymakeit
    I like scoops, but will agree that the Italian cars look the best.
    On a fat fender maybe a small reverse in front of the scoop before starting the opening. Would be hard to do and keep it looking correct.
  5. Phillips
    Phillips
    Are you sure Clarence doesn't own a '38?
    Hard to beat the look of the Tbird scoop.
  6. Malcolm
    Malcolm
    from Nebraska
    Running out of room for the blower/carbs in your Coupe? :)
    I like the look of #11 and #12 and think something like that could be pulled off....
    Plus, a scoop like one of those would pull a little of that Doane Spencer Thunderbird feel that you've mentioned before
    http://www.jalopyjournal.com/?p=10237
    Malcolm
  7. BOP-Nut
    BOP-Nut
    HOLY WOW that Thunderbird just stopped me in my tracks. That is bad***.
  8. Ryan
    Ryan
    ADMINISTRATOR
    Wait until you see it in the TJJ in print book...
      117.7 KB
  9. badshifter
    badshifter
    I'd lower the engine 2 inches.
  10. PASTDUEBILL
    PASTDUEBILL
    I think it has a small ford in it. Car like that needs a bad 312 or a cammer.
  11. Ryan
    Ryan
    ADMINISTRATOR
    Me too... But that's not an option.
  12. BOP-Nut
    BOP-Nut
    Oooohhh, thanks for the new background.
  13. duste01
    duste01
    I would be for seriously looking at a smaller profile carb, spacers, intake mill, lower profile air-cleaner, or moving the airbox to the side, whatever it took to modify the engines topside, to stuff it.
  14. First thing that came to mind was this drag roadster
    or Fred Carrillo's T
    or Fugel's T
  15. 3dnsouth
    3dnsouth
    from North Ga
    Just do the Stone, Woods, and Cook thing and let 'er breath...
    (of course you've gotta know the rest of the 'theme', 'flavor', 'character', 'style', whatever, of the rest of the car in question) What looks good on "A", might look like **** on "B". (know what I mean Vern.....)
  16. Roothawg
    Roothawg
    Need more info. What style car? Hot rod? Street rod? Could he pull off a surfer style scoop with a relief cut in the hood?
  17. Tim
    Tim
    from KCMO
    I'd say run a stylish shaped blister like grimlock urm
    Kevin lee's roadster had. Could look at blisters made in hood sides to clear hemis in model A's and B's for inspiration?
  18. S.F.
    S.F.
    scoop....
  19. S.F.
    S.F.
    hood bubbles are good too....would match the profile of the tops of the front fenders on a late 30's Ford.
      62.2 KB
  20. Sidedraft webers. Your 38 will look funny with a scoop if not done RIGHT. But I have faith in whatever you do.
  21. Dreddybear
    Dreddybear
    ^ I agree a cl***y solution would be a graceful bubble..
  22. Jack Luther
    Jack Luther
    No matter what he does, it's always going to look better without a scoop.
  23. kaydub
    kaydub
    from Cali
    You talking about molding a scoop into the hood? Or cutting a hole in the hood and having a scoop peek thru??
    Gonna be tough to pull off on a 38'..Just hard to picture on that hood.
    I just hate the idea of a molded scoop on a racy car. Just seems like your trying too hard on a purpose built car...
    I would consider cutting a hole and have a smaller version of the Greer/black/prudhomme scoop peeking thru. Trimmed up a little different, but same idea..
    Getting the angle of the top of the scoop is gonna be tricky regardless. I mean, same line as hood? A little bit more upright??who knows?
  24. Slick Willy
    Slick Willy
  25. bowtiemyk
    bowtiemyk
    Just cut and finish out a hole in the hood and let your stuff show. You'll have to cut anyway or ditch the hood. Real hotrods don't have hoods, except behind the wheel!
  26. Ryan
    Ryan
    ADMINISTRATOR
    See, I think Clarence should see this as a rare opportunity to do something DIFFERENT and TRADITIONAL. However, there is a really fine line between "different" and "Jesus god, what the **** did you do to that car?"
    And at the end of the day, not even "different" is enough. It has to look right.
  27. crosleykook
    crosleykook
    from sackamento
    Those sportscar bubbles are pure car ****, but for a '38 Ford application I gotta vote for something along the lines of 3dnsouth's solution.
  28. Slick Willy
    Slick Willy
    Different AND jesus god!
  29. oldrelics
    oldrelics
    from Calgary
