AOD tailshaft counter weight?
Discussion in 'The Hokey Ass Message Board' started by tommyd, Jun 2, 2012.
  1. tommyd
    tommyd
    from South Indy
    Any problem with getting rid of that piece? I removed it today to clean and detail it and the aluminum it bolts too just crumbled.
  2. Nash-Time
    Nash-Time
    The main reason for that part is vibration and harmonic cancellation in the factory car. I'd just call it an OTS part (over the shoulder) and let it hit the s**** bin.
  3. Da' Bomb
    Da' Bomb
    Lose it. Not needed.
  4. millersgarage
    millersgarage
    hang onto it, if your car shakes when its done, put it back on.
  5. tommyd
    tommyd
    from South Indy
    Thanks for the reply's. Guess I'll leave it off but keep it in the shed for a while.
  6. 65COMET
    65COMET
    I have done two AOD swaps into Falcons,both used brand new driveshafts with NO counterweights,NO vibrations!! One has a 347 and one has a 427W,both are street drivers[A LOT]!!! ROY.
  7. grabrr
    grabrr
    I don't have one on my AOD, but I do have a bit of vibration around 65 MPH, but that could just be something else...
  8. ssimpala
    ssimpala
    If it's in your Fairlane you may need it to soak up vibrations at higher speeds...depending upon rear gearing, etc. A lot of newer cars use aluminum drive shafts for this purpose. I discovered that the newer Crown Vic cop car shafts fit my '95 Impalas and work well with 4.10 gears. Maybe measure your shaft and hit the wrecking yard. Try it first without the balancer...maybe it's fine, but just a thought.
  9. moefuzz
    moefuzz
    :rolleyes:
    Yeah that could just be a side effect of Touretts's Syndrom, do you find yourself blurting out swear words for little or no reason???
  10. use it for yard art !!
  11. tommyd
    tommyd
    from South Indy
    You can't have ANY metal yard art around here. DANG S****PERS! They even tore my aluminum address marker right off my post.
  12. OLDSMAN
    OLDSMAN
    That part was done by Ford to eliminate harmonics in some vehicles. For us in the car hobby it is just what it looks like, just junk
  13. Ole don
    Ole don
    Some AOD equiped F 150's had about a three pound chunk rivited to the back of the cab to cancel a vibration in fourth gear. Try it, it may get smooth.
