Need help
Discussion in 'The Hokey Ass Message Board' started by WV junkman, Jun 3, 2012.
  1. WV junkman
    WV junkman
    I am trying to get an accurate measurement from lower part of door jam to center of rear axle on a 1955 Chevy 2 door sedan. Any help will be appreciated.
  2. WV junkman
    WV junkman
  3. WV junkman
    WV junkman
    I need to get rear wheels located in the correct location.
  4. WV junkman
    WV junkman
    Thought someone said once this is the most knowlegable forum on the web for tri five Chevys. This should be an easy question.
  5. nutajunka
    nutajunka
    I'm guessing that your rear wheelwells have been altered? If they are going to remain the same you could just find the center of your wheel opening and drop a plumb bob to find center with the car at final ride height.
  6. WV junkman
    WV junkman
    Yes its altered a bit, but the quarter panel has also been cut. I'm trying to set the axle correctly so when I have new quarters installed it will be correct.
  7. roughneck424
    roughneck424
    You might get more helpers from the 55 guys if you had 55 Chevy in the ***le. I would help but no where near my car right now.
  8. Rich Rogers
    Rich Rogers
    From the "step" at the front of the 1/4 panel to wheel center is 39 inches.
  9. 40streetrod
    40streetrod
    from nj
    how about just working off the wheelbase, which is 115 in instead of the door jam?
  10. WV junkman
    WV junkman
    Swapping the whole ch***is. The wheelbase is correct just trying to position the body over it properly. The door jam I thought would be a good reference point.
