Vicious Vibration.....i figured out why
Discussion in 'The Hokey Ass Message Board' started by PossumJR., Jun 4, 2012.
  1. PossumJR.
    PossumJR.
    from Walls,MS
    This is the cause of the most violent vibration ive ever experienced in a hot rod. On the interstate at about 75mph she started shakin and bout took the steering wheel out of my hand. Got off the interstate and crept back home( about 15 miles) and this is what i found.....after seeing it i couldnt believe it made it home without exploding.
  2. deto
    deto
    you got lucky
  3. Model T1
    Model T1
    I had one 1/4th that bad and it shook like crazy. After I took it off it blew out! You were lucky!
  4. Ranunculous
    Ranunculous
    Wonder what kinda pups it's gonna birth?
  5. martin
    martin
    That was the Part # on the side wall, NOT the P.S.I. :D
  6. henry29
    henry29
    I've never seen a tire do that before. How old is it?
  7. tommyd
    tommyd
    from South Indy
    Wow! Bet it tested every fastner on your car for ya!
  8. F&J
    F&J
    Usually caused by hitting a pothole a few weeks, or a few months ago.
  9. tb33anda3rd
    tb33anda3rd
    that makes sense. i always thought it was from sitting all winter.
  10. bobss396
    bobss396
    I've seen worse than that, not on any of my rides. I've had them 1/2 as bad blow on me before... a sin of throwing junkyard radials on my cars when I was virtually broke. They do give you plenty of warning most of the time, glad you got home safely.
    Bob
  11. gnichols
    gnichols
    from Tampa, FL
    Holy smokes. I see there are still nubs on it, any warranty replacement for ya? Gary
  12. go-twichy
    go-twichy
    that tire's going to give birth to a spare.
  13. JimInrADFORDva
    JimInrADFORDva
    I had that happen once, many years ago, while driving a Pinto on the interstate. It was...interesting.
  14. PossumJR.
    PossumJR.
    from Walls,MS
    these tires probly only have about 5 or 10,000 miles on them. The interstate i had been traveling on had alot of construction goin on and had lots of dips and potholes im guessing thats what the cause was but im like everybody else i cant believe it made it home. Ive had tires come up with quarter size bubbles and blow i dont know how this one made it.
  15. tfeverfred
    tfeverfred
    That may be the miles, but I bet the age is old. There's a number on tires to check the age.I don't know where it is, though.
  16. squirrel
  17. SaltCoupe
    SaltCoupe
    from Indiana
    It's a wonder that thing held together...you got lucky.
  18. PossumJR.
    PossumJR.
    from Walls,MS
    Ill check the date they I got them about 2 years ago and they had been on another car for a couple years but had not had many miles put on them
  19. squirrel
    The miles don't have much to do with it...time and potholes seem to be the problem.
  20. Dyce
    Dyce
    Looks like a broken belt or two. I had that happen a few times with old tires. Tread looked good on the tires but they came apart inside. Even had wires poking through the tread.
  21. PRB
    PRB
    from Az
    OTOH it did it's job and got you home, bunged up or not.
  22. Unkl Ian
    Unkl Ian
    Had that happen several times with bias ply tires, only once with radials.
  23. Bounder
    Bounder
    That's what we used to call a "Dog Knot" here in east Tenn. Couldn't have been any fun on the big road.
  24. droptop 63
    droptop 63
    from Texas
    What brand of tire is that? Looks like the lump is too low on the sidewall to be pothole damage.
  25. 1ton
    1ton
    That must be one of those eleven year old tires that our govt' is so worried about.
  26. Bad Daddy
    Bad Daddy
    That's not too bad. I had one do that so severely the entire tread was shifted over so it kinda looked like an S.
  27. The tires they are producing these days don't seem to be built to last long. Check out the tread left. Back in the day you could wear the tread off and not have them fail. Pat
  28. need louvers ?
    need louvers ?
    I have had the same problem here lately. Now, we really don't have potholes around here too much, and our roads are pretty flat. We put a brand new set of tires last fall on the girlfriends way O/T daily driver, and about a month ago she said it was "going bump bump bump" Thought she was probably nuts (She is a female you know...) and put her on a plane to Hong Kong (that part was preplanned too). Drove her car the next day.... Well Damn! Took it down to our tire store here in town, and three of the new tires were separated! Looked almost as bad as what you have there. Maybe sometimes I SHOULD listen to her...
  29. PossumJR.
    PossumJR.
    from Walls,MS
    these are coker white walls and im wondering now if i should be worried about the other 3....They look fine but so did this one a day prior to this.
  30. Bigchuck
    Bigchuck
    from Austin, TX
    Seems to lots of talk on the net about tires these days. The 7yr life span is a biggie. How did that come up? I would think time on the road would be more of a factor, or maybe time exposed to UV rays. There seems to be some missing information. My guess would be that the EPA changed what is allowed in the manufacturing process. Maybe no longer allowing the addition of something in the mix of stuff tires are made of that stabilizes them. The 7 year thing would only make sense if a certian coumpound were to leach out of the tires at a rate consistant with the 7 yr number, or the rubber begins to break down attributable to the lack of something in the compound. Maybe some one out there in HAMB land has a answer.
