Projects 1952 Studebaker Truck Build
Discussion in 'The Hokey Ass Message Board' started by Jimbacca, Apr 8, 2012.
  1. Jimbacca
    Jimbacca
    Just putting a thread out there on my Studebaker truck project.
    Delivery day.
    [​IMG]<br>
    [​IMG]<br>
    [​IMG]<br>
    [​IMG]<br>
  2. Jimbacca
    Jimbacca
    Engine progress-
    Changed the 3/4 Airlines to 3/8's and mounted valves.
    New shiny Air cleaner<br>
    Hydroboost for the braking and steering
    Upgrade Master Cylinder
    Relocate Brake ***embly to clear tire.
    Fill Holes in firewall
    Dual Line PS Pump
    Serpentine Pulleys
    Aluminum Brackets
    Stainless Upper and Lower Radiator Hoses
    Existing Plate removed
    Move complete
    LWP, PS and Hydroboost Brakes done
    New Brackets and Radiator Hoses Done
    Next up for the engine compartment is start making some panels to clean everything up.
  3. skull
    skull
    what frame is under that?
    Later :cool:
  4. Jimbacca
    Jimbacca
    Mid 80's S-10 Frame front to back.
    94 S-10 blazer rear end since the 70's camaro rear end went out.
  5. Jimbacca
    Jimbacca
    Interior
    At drop off
    Mid 80's GM Door handle and mechanism
    Door panels in.
    Switchbox for the air
    Removed the underdash Sears AC unit
    Shifter boot
    Air Gauges mounted under the dash
    There were some factory holes that need to be covered up. This one was under the driver side seat. Nice warmer on long drives.
    With the brake move a new pedal ***embly was needed. The brake pedal uses an s10 curved portion with an astro van upper ***embly.
    The factory holes for the column, pedal and shifter holes were no longer needed
    I had to put in some seat belts for the family adventures. The seat will be rewrapped in dark material.
  6. Jimbacca
    Jimbacca
    Rear
    Rear of the truck when I got it.
    Rear Suspension
    New rear lights and 3/8s airlines installed
    New disc brake rear end with limited slip to replace the broken 72 camaro rear
    Skipped a few things but here's when the rear bags were redone and the notches cleaned up
    Everything re***embled and painted for now. Watts and a 4 link are next for the rear.
  7. RMR&C
    RMR&C
    from NW Montana
    You are making some nice progress! What's next? Any plans for paint?
  8. Looks like a ton o fun!
  9. Jimbacca
    Jimbacca
    Next up is to get the suspension complete and start cleaning up the underside of the truck. Paint is down the road. My daughter hasn't figured out the color for 'her' truck.
  10. 48bufordsled
    48bufordsled
    from u.k.
    Very nice !
    Heres mine
  11. Jimbacca
    Jimbacca
    Nice. I just ordered the stock side windows and hardware. It will eventually go single piece like yours.
  12. 49stude2r6
    49stude2r6
    Nice work on the truck. Looks like everything you touch on it gets better.
  13. Jimbacca
    Jimbacca
    Thank you. It's fun making things better. Nice looking studebaker you are working on. Engine panels looks clean.
  14. 49stude2r6
    49stude2r6
    Thanks, What kind of carpet/floor mat is in your truck. I need to do something a little better with mine so I can cover some sound deadening/insulation.
  15. nunattax
    nunattax
    how well does the hydroboost work
  16. Jimbacca
    Jimbacca
    I drove the truck without it. Power box but no ***ist and manual brakes. Steering was interesting. Brakes were usual manual.With the hydroboost it drives so much nicer. Steering is really nice brakes are perfect. When I went to disc in the back helped it stop great. I think its a neat thing to put on. I've got to do something with the lines. I pulled the lineset from a full size chevy so they are a bit long. They will eventually be steel braided. If you want pretty I'd go with Hydratech. I had one for a previous project and was a great unit. I did this one low budget. The unit is out of an astrovan.
  17. Jimbacca
    Jimbacca
    The previous owner had the carpet done by his interior guy. He's going to get me the information.
  18. stillrunners
    stillrunners
    from dallas
    wait...are you sure that's a Studebaker truck?....it's yours....and lookin' good....
  19. Jimbacca
    Jimbacca
    Well the windows parts came in today. The main gl*** was cracked before. So I guess the bubble wrap was just to show it was fully broken by the time I got it.
    The one 'good' windows is the p***enger wing
    The good part. Have pretty much everything to roll up windows. Stainless trim for the main windows. Downside missing the rollers that help the frame slide up and down. So may just straight into rail power windows.
  20. Jimbacca
    Jimbacca
    Some minor updates
    Window cranks in. Pull handle until I make the armrest.
    The parking lights are from a 52 GMC. One was broken so found some new ones. New gaskets and painted the housings. Here the before and after with the new lens and paint
    Underside of the hood was not very nice looking so Sand, Acid , rust converter paint and all cleaned up for now.
  21. Jimbacca
    Jimbacca
    Picked up and installed a rear swaybar for it today. Waiting on some suspension parts to get finished machining so that's holding up the rear suspension
    The daughters are liking Tan with some metallic in it as the final color of the trucks.
  22. RMR&C
    RMR&C
    from NW Montana
    Where did you get the sway bar? Is it custom or from some other car? I could use one like that on my F-1....
    Your truck is looking good!
  23. Jimbacca
    Jimbacca
    It's off of a late 90's gen 2 4dr s10 blazer with a 4.3 engine. Surprised it had a complete disc to disc rear end still in it. The sway bay unbolts easily and all but the link brackets come right off.
  24. RMR&C
    RMR&C
    from NW Montana
    Thanks man, I forgot you are running an S10 frame.....will check it out and see if it will work with my stock frame.
  25. Jimbacca
    Jimbacca
    The mount to the frame is just a hole I drilled for the link bolt to go through on my notches.
    The way the sway bar was mounted stock was to the back of the rear end. I moved it underneath so it would clear the suspension brackets on my rear end. Depending on how wide your frame is shouldn't be too bad to add on.
  26. 32ford07
    32ford07
    love a stude!!
  27. edweird
    edweird
    me too!
  28. jroberts
    jroberts
    I'm lovin' your truck. Keep up the good work.
  29. Jimbacca
    Jimbacca
    Thanks for the comments. Some cool looking studebakers you guys have there.
    Worked on the fuel system today and wiring up the newly restored lights. Going to be doing up the polish and chrome tomorrow.
    Chili cook off car show at St Rose Lima in Simi.
  30. Jimbacca
    Jimbacca
    Solid day at the shop. Burned up a shirt but we made some progress on the rear.
    Rear frame and suspension work day
    Bed Removed
    Suspension, Air tank, compressors and other lines removed. Brad degreasing the frame
    Old mounts cut off
    Some grinding and fire later cleaned up
    Brad welding in some plate to fill in the gap from the factory hanger to the plated frame
    Lower link bar in place. Tacked for now to the rear end
    Back to sleep until we finish up the 4 link. Along with 2 AZ compressors, air tanks and custom fuel cell
