Ford truck pitman arm
Discussion in 'The Hokey Ass Message Board' started by tysond, Jun 8, 2012.
  1. tysond
    tysond
    I have what I think is a mid 40's ford truck steering box. It's push-pull steering, but not an F1. The internals are identical to the F1 design, but slightly larger. I'm trying to locate a pitman arm for it, but I don't even know exactly what to look for. Does anyone have any ideas? I'll try to get some photos tomorrow if that helps.
  2. Stovebolt
    Stovebolt
    Sounds like an F100 box.
    Get a measurement of the spline that the pitman arm fits onto.
    I run a 49-54 Chev pitman arm on an F1 box.
    My memory tells me that a Falcon/Mustang one fits the F100 box.
  3. tysond
    tysond
    Not F100, it's splined just like 37-48 car ones, but slightly larger. I have an early f100, and 40 Ford p***enger car box to compare. F100 is a pinch bolt.
  4. Stovebolt
    Stovebolt
    Well cut off my legs and call me shorty
    I believe you're right.
    Best we go back to normal programming.
  5. Ford pickups '35-'47 are cross-steer.
  6. tysond
    tysond
    Maybe COE? Larger truck maybe? I'm clutching at straws here. The box looks great and will work for my build. But it's useless without a pitman arm.
  7. Tsquared
    Tsquared
    from Pratt, Ks.
    How does the pitman attach to the box? If i remnember correctly, the F1 uses a cross bolt through the grooved gear box shaft...and the F100 is held on with a large hex nut on the splined shaft...or maybe I said that backwards.
  8. tysond
    tysond
    Hex nut. The hex from my box fits the Ford car box.
  9. Dale Fairfax
    Dale Fairfax
    Do you have a dial or digital caliper? If so, measure the diameter over the splines at the fattest point and let us know.
  10. Tsquared
    Tsquared
    from Pratt, Ks.
    Yep! I told you wrong...I went out and checked...I have a `55 F-100
    column and gear box ***embly ; It uses a cross bolt to hold it [pitman arm] to the gear sector...The F-1 and older will have the hex nut.
  11. bolt_boy_49
    bolt_boy_49
    from USA
    I have a pitman arm from from a 49 f6 box that I have no use for. Its yours if you want it just pay postage. I should check, is you box a gemmer box?
  12. tysond
    tysond
    Right sector is mine, left is Ford car. Spline measures 0.125".
  13. NealinCA
    NealinCA
    The box appears to be 48-52 F-4, 5, 6. The sector shaft is 1-1/4" right? Boltboy's F-6 pitman arm should work, or any other 32-52 BIG truck pitman arm.
    Neal
  14. tysond
    tysond
    Thanks. What will the ratio be like? Too slow?
  15. bolt_boy_49
    bolt_boy_49
    from USA
    The pitman is about 8" center to center. I dont know what kind of ratio that would give you. For comparison my 1.5 ton Dodge has a 10.5" pitman arm and it steers well... like a big truck.
