“What joy have I in June's return?" The June 2012 Banger Meet
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Jun 2, 2012.
  1. RussTee
    RussTee
    Or maybe just a crazy old has been damit I have been driving this thing for 40 years as it is.
  2. 4bangertroy
    4bangertroy
    from Phoenix
    Here is a video of the bangers running a the Antique Nationals. Clark Crump in the blue coupe won the flathead cl*** and LimeyNick won the overhead cl*** in Cigar Larrys roadster pickup.
  3. A Rodder
    A Rodder
    Just got home with thus little gem. A stocker with a balanced A motor. So much smoother than my coupe.
  4. BCCHOPIT
    BCCHOPIT
    Very nice find...
  5. crminal
    crminal
    A Rodder........
    She's a fine lookin' machine. Congrats.
  6. MATACONCEPTS
    MATACONCEPTS
    should I buy a polished winfield head for $250 ??? Or leave it alone??? are the benifits??? Do they blow head gaskets easily???
  7. Hapydz
    Hapydz
    If you don't buy it someone else will then you will be kicking yourself in the ****...lol :eek:
    Ron
  8. A Rodder
    A Rodder
    Hope, you buy one from that bad *** who posted two spots above you like I did!
    His name is Bill
  9. MN Stumpjumper
    MN Stumpjumper
    If you don't buy it, tell me where it is so I can.
    Should get you more power.
    Won't blow gaskets if it's flat and installed properly, then retorqued several times.
  10. LOWCAB
    LOWCAB
    from Houston
    Just thought I would throw this in here.
  11. Hapydz
    Hapydz
    Very , very nice ! Some details .....
    Ron
  12. youngster
    youngster
    from Minnesota
    Throw some more in here!!
    Ron
  13. Super88
    Super88
    LOWCAB, that is definitely impressive looking!
  14. That's the Spurgin Giovanine '25 Chevrolet engine- one of absolute favorites :)!!!
  15. A Rodder
    A Rodder
    This isn't mine, it's a friends who is somewhat private. Ill tease you with pics but really don't know alot about it other then its a runner.
  16. Halfdone
    Halfdone
    G'Day everyone
    I just bought another banger
    It was advertised as an A, however has a fuel pump boss and the taller side cover so is likely a 32 or later
    It has a front motor mount that extends out either side of the crank. Looks like pictures of a 34 banger front mount
    However the bell housing has no provision for side mounts. All the ford bangers I have seen have had side mounts on the bell??
    four bolt water pump on head
    Any ideas what year it is ??
    It is frozen.
    Any pointers on freeing it?
    My first step was going to be to stick it on an engine stand, pull the sump and side cover, and then fill the cylinders with a diesel/ATF mix
    I'll post photos
  17. noboD
    noboD
    It could be stuck from being broken. Might as well take it apart, carefully.
  18. ebtm3
    ebtm3
    '32 and later, the rear mount was on the rear of the transmission.
    And if it's a Ford head with a 4 bolt pump, it is either a stock A head, or an A "police" head--which is slightly higher compression, and has a large B cast on top. At least the police heads had the B when they came from the factory---we used to grind the letter off so that the head looked like a stock A --sneaky cusses that we wuz--the little bit more compression helped--but not much.
    Herb
  19. Reddy
    Reddy
    A Rodder
    Was checking out the pictures of a engine you posted It looks to have a ford V8 water pump. Which looks to me has a pulley that a fan mounts to it Where did he get it, or was it custom made?
    Thank You Mike
  20. A Rodder
    A Rodder
    Pm your email address and I will see if I can get a better pic.
    I know it has some custom looking parts between the had and the fan for sure.
  21. RussTee
    RussTee
    Reddy it is a v8 water pump look at the alloy casting between the water pump and the head it is an adapter they should be available from Sac Vintage Ford.
  22. That looks like one we sold to Minnesota a few years back!?
  23. youngster
    youngster
    from Minnesota
    I think he's asking about the pully/fan mount.
    Ron
  24. LOWCAB
    LOWCAB
    from Houston
    You are correct about it being the Spurgin Giovanine car. Here are some shot of it when it was getting ready for Pebble Beach.
    That's me in the white shirt.
  25. A Rodder
    A Rodder
    The owner I got it from had it for about 20 years and brought it from CA.
  26. Halfdone
    Halfdone
    Thanks Herb
    Every B I have seen here must of had an A bell housing swapped on then, because they have all had A style side mounts ??
    I have only seen 3 or 4 in the flesh here in Australia, not real common
    Here is the one I grabbed, should have put the link in my original post
    http://www.ebay.com.au/itm/28088918...X:IT&_trksid=p3984.m1439.l2649#ht_1203wt_1396
    I haven't tried spinning it over yet
    I figured I would let it soak for a few weeks first
    Hopefully it is just frozen from rust etc
    It will get a rebuild with inserts and a cross drilled crank
    Thomas head
    Wico mag
    undecided yet on cam and lifters
    also undecided on rods. Probably aftermarket with inserts
    I also have a little (1500cc) S.C.o.T blower that MIGHT go onto it too
    My theory is it would be Big enough to wake it up, without overloading the centre main.
    Undecided if it will go on this banger, or just decorate the wall
    My Thomas head has tiny crowsfoot style chambers, and I think getting the compression low enough to tolerate the small bower may be an issue
    So I might need a different head to match with the blower setup, and stick the Thomas on one of my A Bangers
    I also have:
    Mac's bell housing from NZ
    Crazydaddyo S10 4WD adapter for the torque tube
    Halibrand 101 QC (first casting style, takes AR gizzards)
    I need a S10 4wd T5 (anyone help there??)
    It's going into either my 22 T roadster (early 40's lakes style), or my 27 T roadster (late 40's C.R.A style) ........... both just piles of bits at present
    Or it could sit for years waiting for me to stop fiddling with bikes and pickup trucks :confused:
  27. Halfdone
    Halfdone
    Update
    Day time here, so I'm hooking in striping it, while you guys get a rest
    All good news sofar
    Spotless inside the side cover. nice coat of old oil on everything. No rust or signs of broken bits
    Same story inside the bottom when I pulled the sump. A small bit of sludgy water in the bottom, but no visible rust damage. Bottom of bores look fine
    Best bit ............ counterweighted crank
    Dizzy is rusted internally, and frozen into it's hole ......so that may be why it won't turn over. I remember reading they do that. I will do a search on pulling a frozen dizzy, I know I saw a thread somewhere on that. Don't want to damage it.
    Happy Camper ....... time for a beer :D
    Further Edit
    Dizzy came out after a soak in ATF. Still frozen, but I will let it soak in kero for a week
    Head popped with one whack from a rubber mallet
    Bores are rust caked above the piston.
    I will soak it in an ATF diesel mix for a week and then see if the bores clean up and the pistons will budge
    Looks like a great B to start a build from ...... VERY happy camper now
  28. BHT8BALL
    BHT8BALL
    Who are the weirdo's eating Pizza?
  29. CA 31 Victoria
    CA 31 Victoria
  30. So LOWCAB and BHT8BALL,
    Did the rebuild of the SB engine include using the Curtiss Jenny OX 5 connecting rods, or did it get something a little more tame?
    (Stevie G and I are in the process of getting a good balance of crank throw, rod length, and pin height)
