Air Conditioner scavenging
Discussion in 'The Hokey Ass Message Board' started by salf100, Jun 9, 2012.
  1. salf100
    salf100
    So I've been thinking with all this hot weather outside, has anyone stole an A/C unit from a different vehicle and adapted to their hot rod? Saw a tech tip once where a guy used an a/c unit from the back p***enger area of a van and adapted it to his rod. Post pics, techs and info if you got it.
  2. Orlando1701
    Orlando1701
    I've herd of this. I'd like to know, living in Florida I really want to get A/C run in my 50' Ford.
  3. salf100
    salf100
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Put this in my '54 Ford for a "retro" look, it is from a 1965 Mustang since I have swapped to a 5.0 & AOD I was able to use the early Mustang brackets and compressor,condenser and receiver dryer.Another thing that may interest some of you is a 66-67 Mustang radiator is a bolt in for 1949-56 Fords so you can also use the matching fan shroud.
  5. cryobug
    cryobug
    I have used one from Datsun B210's in a 37 Chevy pickup before. They were like a dash hanger unit with a cap over the front to install vent hoses. It went under the dash nicely.
  6. derbydad276
    derbydad276
    Iu used to work in a auto acc. shop in the early 80's back when a/c wasnt standard
    there were several companys that made after market a/c units that would fit under or in the dash
    that ford unit there was the only way you got air in the early 60's fords
    and i remember adapting several of those for friends
    if you get one from salvage yard and the system has been open fro a long time flush the coil with denatured acholol and be sure to evac it for a while same goes for a used condensor under the hood use a new reciever dryer fro 134a
  7. FrozenMerc
    FrozenMerc
    Something like this??? (I couldn't resist)
    Swamp coolers are period correct and worked well in dry climate areas.
  8. daddio211
    daddio211
    Not hot rod related, but a friend of mine recently used a Mazda 323 compressor to put AC in a VW notch back. Reason I bring it up is that the comprssor is REALLY small, but you'll probably need to machine a different pulley for it.
  9. salf100
    salf100
