best way to pre-oil a 1968 318 mopar motor for initial start up??
Discussion in 'The Hokey Ass Message Board' started by MoparMan4GZUZ, Jun 9, 2012.
  1. Reading the other pre-oil thread got me thinking. I am finally getting ready to do the initial start up on my 53 Dodge truck, but am not sure of the best way to pre-oil the motor prior to the initial start. This is my first new Mopar motor and since these engines have a gear driven shaft for the oil pump, how do you pre oil it without taking out the distributor and the oil pump drive gear??? I did a search, but did not find anything that answered this question. Thanks in advance for all the advice.
  2. 35desoto
    35desoto
    Take the distributor and drive gear out
    Drop in a slotted hex drive shaft in onto the oil pump drive
    Hook it up to a drilling machine
    And let it do the work
    As the oil ressure builds up the loading will go on the drill however if its half decent all it will do is make it work
    If not you can burn the drill out!!
    done it many times and its good to see the oil squeezing out of the rockers once the oil pessure builds up - you know you have a good supply to all the engine before firing it - great bit of security!!
  3. What 35 Desoto said, but turn over the engine slowly a revolution or two to allow oil to get to the top end. The dual oil galleries that feed the top end via the deck/heads will get oil by turning the engine over while priming.
    Rat
  4. spooledup
    spooledup
    I've changed from pre oiling. When you pre oil it washes the
    best lubricants (***embly lube) away and they cant do there job.
  5. barney rubble
    barney rubble
    I agree with spooledup. I've built a bunch of Mopars and never pre oil them. Thats what your ***embly fluids are for. Its really only seconds before everything lubes.
  6. 48 Chubby
    48 Chubby
    For years I've just pulled the spark plugs and spun it with the starter till I got oil pressure. This will also get fuel to the carb, and they usually fire right off.
    Works for me.
  7. FEDER
    FEDER
    If You were still down the street I have the tool for that. OTHELLO ? What made You move that far a free house? Fed
  8. hey Mr. Fed!!! Work offered me a chance to move over here to where we actually wanted to retire anyways. 6 acres. shop is ready to work in and we love it here. you need to come visit. Bud
