anyone used a hydraulic or electri brake booster ?
Discussion in 'The Hokey Ass Message Board' started by satan'schariot, May 1, 2012.
  1. morepower
    morepower
    from northeast
    Thanks Cosmo. Where do I find a diesel delivery truck hydro booster? Suppliers? Any info appreciated.
  2. JSanford1974
    JSanford1974
    Do you got any pics of that install? I'm putting a 2005 GM 2500 hydroboost setup in my 53 Chevy 210. The hydroboost mounting point is flat, so it should fit the firewall perfectly. I'm going to buy the pedal ***embly from the same truck. So the pedal ratio is factory. I'm running a 5.3, so I'll be OEM from the pump, hoses, to the hydroboost setup. All I have to work on is the brake lines, which should be fairly easy. And I'm hoping the brake pedal requires little fab work. I'm hoping it works like factory.
  3. 40FordGuy
    40FordGuy
    My former employer's truck fleet (GM vehicles) had a lot of hydro boost units, and during my 18 yrs there, never had one fail. I would use one any day.
    4TTRUK
