need help to id mopar transmission!!!
Discussion in 'The Hokey Ass Message Board' started by agutto13, Jun 2, 2012.
  1. agutto13
    agutto13
    Hey guys need some help to id my transmission I just pulled out of a 55 dodge royal. I ran the casting number (2801260-7) which came back as a 727 I think. The car had a 318 in it with this ****** behind it just sitting in there. Torque converter wouldn't bolt up to the 318 and never tried the bellhousing. The ****** has a drum on the tailshaft for the ebrake and the number above the pan is j2829317 4169463 I searched that number and nothing came up... please help! Thanks!
  2. squirrel
    picture?
    the 28****x number is from the late 60s.
    If you post some pictures of the front where it bolts to the block, and the pan near the dipstick, we could see if it's a big block or small block trans, and if it's a 904 or 727.
  3. agutto13
    agutto13
    Unfortunately I can't post pics. Would a late 60s car have a torque tube driveline and the ebrake on the ******?
  4. squirrel
    No....that's why posting pictures would be such a big help.
  5. R Pope
    R Pope
    It won't be a torque tube drive, Mopar didn't use them. Probably a trunnion style u joint on the E brake hub.
    need louvers ? likes this.
  6. squirrel
    There were drum parking brakes used on Mopars in the late 60s, in motorhomes....so it could be a trans out of a motorhome, connected to an early driveshaft.
    But it's really hard to see what you have.
  7. R Pope
    R Pope
    Early aluminum Torqueflites had that style E brake in the cars too.
  8. plodge55aqua
    plodge55aqua
    from Alberta
    Have you ever left the park brake on and drove for a bit.. It stinks.. :)
  9. gatz
    gatz
    had a 50 Dodge with a small rear xmsn gear lube leak.
    best way to "clean it up" was to set the ebrake a little and drive 'till the lube burned off.
    yes, it did stink.
  10. agutto13
    agutto13
    alright finally got the pics!
  11. might just be an old Powerflite 2speed...similar to a 2speed powerglide.....very old unit.
  12. agutto13
    agutto13
    so do you think its the correct one for my 55 dodge?
  13. 73RR
    73RR
    Your trans is a small-block 727, 1966 or newer.
    The hole in the top-front of the case is indicative of transmissions used in vans and motor homes (this is where you would check timing), and the parking brake pretty much says "motor home' since it was never used in any light duty applications.
    benchseat4speed likes this.
  14. squirrel
    big block motorhome trans, like he says. From the casting numbers you provided earlier, it's likely to be from the late 60s-early 70s.
  15. RodStRace
    RodStRace
    What 73 RR said.
  16. agutto13
    agutto13
    The only thing is that the 318 flex plate bolt pattern is to small for the torque converter.
  17. R Pope
    R Pope
    The flex plate is for a 904.
  18. agutto13
    agutto13
    Duh! Lol thanks guys!
  19. R Pope
    R Pope
    Ooops! Sorry, guys. The T'Flytes with the driveshaft pincher E brake were cast iron case ones, the car aluminum case transmissions never used them. Trucks and motor homes did, though.
  20. Finsinthemirror
    Finsinthemirror
    Wrong on that, all chryslers from 56-61 have the cast iron trans (no flexplates what-so-ever) but the 62 chrysler has an aluminum 727 trans with the e-brake on the tailshaft.
  21. 1930 A
    1930 A
    Chrysler had two size flexplates. one fit the torque convertors with the narrow ring gear like your trans has and the other fit the convertors with the wide ring gear, probably what your motor has
  22. 340HilbornDuster
    340HilbornDuster
    Why start a new post...
    I hope someone can enlighten me on this...?
    904 #1 to be identified!
    2538338Y
    Came out of a valiant station wagon....60 something...
    [​IMG]Like this Looked like this one...
    He told me it was NOT a push****on shift.
    It had a two hole filter in it.
    There's no pump in the back of it......
    I currently don't have the pump in it...Don't know what I did with it..
    I might be running the pump in my Dusters 904 right now...(runs great!)
    20160730_162301 (Small).jpg 20160730_162310 (Small).jpg 20160730_163150 (Small).jpg
    top.
  23. 340HilbornDuster
    340HilbornDuster
    I opened this 1973 318 standard 904 for reference.
    3681063
    Sorry, don't know why the pictures rotate sometimes...sometimes not?
  24. squirrel
    25****x part numbers are from around 1966-67, eh? and you might find a casting date code on some of the parts if you look carefullly.
  25. 340HilbornDuster
    340HilbornDuster
    How do you identify a double pump 904/727 unit?
    Shouldn't it be a second pump in the on the output shaft?
  26. squirrel
    Yes. I used to know what year they quit using the rear pump but I forgot.
  27. sunbeam
    sunbeam
    1965 was last year for rear pump and cable shift all though 65s didn't have push ****ons.
  28. squirrel
    I think there was some federal safety law that required that all shifters follow the same common shift pattern, so the 65s had a normal shifter, but operated by the cable because they didn't have time to do the linkage redesign until the 66 model year. And yeah, that sounds like the right time for them to discontinue the rear pump. I should go look it up, now that I'm back home....but it's pretty soggy out, rain gauge has almost 3" water in it.
  29. 340HilbornDuster
    340HilbornDuster
    Still Educating myself...hard to find any pictures / info on these...
    (Correction! picture below says "One Piece Aluminum Casing"...Not Steele...Still Learning!)
    There's the rear oil pump! (This must be a slant six unit...starter up high!)
    1962-65 Mopar Torqueflite 727 Pushbutton Rear Pump Assy  Dodge Plymouth 383 426 1.jpg It takes the place of the Governor Support...Have to take another look when I get home today.
    Mopar Torqueflite A904 Governor Support.jpg 62-65 NOS front pump (looks the same as post 65 - I think it's the one that's been whining in my Duster for the last 5 years...)
    Transmission Front Pump Housing A904 Fits Most 62-65 Models NOS MOPAR 2204712.jpg
  30. squirrel
    yup, they replaced the rear pump with just a governor support. And I made it out to the shop and looked in a couple books, looks like all this stuff changed in 66.
