Anybody Using Penta-Star Turn Signal Module
Discussion in 'The Hokey Ass Message Board' started by 327-365hp, Jun 12, 2012.
  1. 327-365hp
    327-365hp
    from Mass
  2. squirrel
    "Hazard Mode - is available all the time and will flash until cancelled. To engage, press both the left and right turn signal ****ons for 1 second. To cancel, press both ****ons again for one second. "
    You can use a toggle switch, but then you won't be able to do the hazard thing. Not much that you'd be missing, I don't have hazards on any of my old cars...
  3. DD COOPMAN
    DD COOPMAN
    squirrel...Would you know whether a similar (in BASIC function, but NO hazard) 3-wire into 2-wire 12v converter would function on a 6v system (in a stock '39 Ford)? Thanks DD
  4. 327-365hp
    327-365hp
    from Mass
    Thanks for the reply Jim! So I just need a momentary on, center off, on, toggle. 3 terminal like this one.
    Btt for DD
  5. squirrel
    My guess is that it won't work, but you'd have to ask the company that sells it, to be sure. If it has relays or electronics, which I suspect it does, they usually don't run with only half the design voltage. But you could ask them....
  6. Scrap Iron
    Scrap Iron
    from Mesa, AZ
    I'm going to be using one with a toggle switch as well, you just won't have the hazards option is all. I am using the toggle that Kwik Wire sales
  7. bolt_boy_49
    bolt_boy_49
    from USA
    Fellas seems to me all you need is a double pole single throw momentary ****on similar to mcmaster part no. 7400k72 connected so that when in the on position the left and right ****ons are sent to ground. This way you can keep the single toggle switch and add a hazard ****on somewhere else.
