Removing Chrome, what's the DYI for that?
Discussion in 'The Hokey Ass Message Board' started by All_6s_and_7s, Jun 12, 2012.
  1. All_6s_and_7s
    All_6s_and_7s
    from Canada
    I had sent my chrome grill parts over to my sandblaster and he tried to clean them up, but as soon as he started the parts started to warp. He isn't set up for baking soda, so what else can I do to remove chrome?
  2. Blue One
    Blue One
    from Alberta
    Nothing that I know of if you want a smooth clean ,unplated surface. Baking soda will not do it.
    Your best bet is having a chrome plater reverse the process, basically a chemical -electrical strip.
  3. All_6s_and_7s
    All_6s_and_7s
    from Canada
    yeah I don't have a plater close by that's why I'm looking for different options. I am painting my grill anyway so I expect to do a little smoothing and body work.
  4. 40StudeDude
    40StudeDude
    Don't bother to take the chrome off, simply use PPG's DPLF40 and spray it...it sticks like glue...then paint if whatever color you want.
    R-
  5. Blue One
    Blue One
    from Alberta
    A big BS to that. It will not stick to the smooth finish of chrome well enough to stay put. A nick or two and the stuff would come off in sheets at a carwash with the pressure wand when he was trying to get bugs off.
    Read this, from PPG:
    DPLF Epoxy Primer mixed 2:1 with
    DP401LF or DP402LF Catalyst provides
    an excellent corrosion–resistant primer.
    This primer provides excellent adhesion to
    many types of properly prepared metal,
    fibergl*** and aluminum substrates, as well
    as plastic fillers. DPLF Epoxy Primer may
    also be used as a sealer and topcoated with​
    most PPG Refinish products.
    Smooth and unprepared chrome plated surfaces are not considered "properly prepared metal surfaces when it comes to painting.
  6. Sumfuncomet
    Sumfuncomet
    Small parts , toss in a bucket with warm water and hardwood wood ashes mixed together. Basically a strong lye, be very careful not to get on your hands or splashed on face or eyes. Rinse parts with water after, scrub with brush and liquid dish detergent. I have used this successfully on small chrome and painted pieces. Do not use an aluminum bucket or aluminum tools to put lye mixture in. Give it overnight to work.
  7. 40StudeDude
    40StudeDude
    Weeee-eeeell, I guess the bumpers on my Studebaker didn't know they weren't "properly prepared" then...I ran them painted for almost 10 years using DPLF40 and lacquer paint...Yep, they chipped but never had an issue with a car wash wand...maybe you guys in Canada have higher water pressure than we do in the states...!!!
    At any rate, what's "all 6's and 7's" got to lose, other than a bit of primer and paint...it's definitely not like it's going to hurt his chrome...!!!
    I think the REAL wording here to understand is: "are not considered properly prepared metal surfaces." Doesn't say anywhere it definitely does not work and won't stick...!!!
    R-
  8. pdunn10
    pdunn10
    you can use a different media to blast with. baking soda or walnut,
  9. Box ém up and freight them to a plater. It costs peanuts to do a reverse chrome. I got an old flaking chromed beam axle and two split bones done for $20NZ ($15US)
  10. Rattle Trap
    Rattle Trap
    I would also vote on sending them to a plater. It's an inexpensive process to de-chrome stuff. And a lot less work too.
  11. 40FordGuy
    40FordGuy
    Question.... Light "scuffing" with wet paper ? Anyone done that ?
    4TTRUK
  12. Rattle Trap
    Rattle Trap
    I have done a light scuffing on chrome but it was in good shape with no defects. Held up good for the few years I could keep an eye on it.
  13. ytt49
    ytt49
    from socal
    Glad to see trying here since facebook did not turn up to much, that link was all i could find.
    good luck
  14. Rude Dude
    Rude Dude
    Like said before it is cheaper to remove at the platers than re-chrome . I had an axle that chrome was shot. Total for removal was $30 dollars.
  15. mashed
    mashed
    from 4077th
    I know this chick. I heard she usually works with bumpers though.
  16. mgtstumpy
    mgtstumpy
    My plater had the grill and bars sandblasted to firstly remove the scale and areas where it was delaminating. He then dipped everything and reversed the process to leave nice metal to work with. Took a little longer but well worth it. He was able to fill all the small pits and do a proper triple plate job.
  17. Chickenlegs
    Chickenlegs
    Ive wet sandblasted body parts without warpage. Basically its the use of a commercial pressure washer with a wand that pulls the media into a mixing head on the nozzle. No dust, no heat.
  18. All_6s_and_7s
    All_6s_and_7s
    from Canada
    Well I asked my wife, she's capable, but unwilling.
  19. All_6s_and_7s
    All_6s_and_7s
    from Canada
    yeah I tried a few of those tricks.....cola didn't work lol
