Flash Me
Discussion in 'The Hokey Ass Message Board' started by Hi*Speed, Oct 31, 2005.
  1. Hi*Speed
    Hi*Speed
    Would anybody happen to know where the turn-signal flasher on a 1955 Ford Ranch Wagon might be? I'm not sure, but I would suspect it could be in the same place as other '55 model cars. Not knowing those locations either, any help would be appreciated. Thanks.
    Mark
  2. BlackFlag
    BlackFlag
    Back of the gauge cluster? Thats where Ive found it on my 59 and my dads 67.
  3. Fairbanksbanjo
    Fairbanksbanjo
    from Georgia
    Thanks for this. I've been searchin' for mine.. Your comments will make it a lot easier..
  4. spooler41
    spooler41
    Hi*Speed, As I recall the signal flashers were often found just hanging out of the wire harness on a short pig tail with the plug in connector attached.
    I believe the flashers that plug into the fuse panel didn't come along until the late 60's or early 70's.
    Hope this helped out.
    Jack
