EZ wirring harness (all black) have the oppurtunity to score one
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Jun 15, 2012.
  1. 56 ford custom
    56 ford custom
    from Socal
    I have the oppurtunity to score a 21 circuit all black and labeled for $160 and retail is $185. Not sure if I should go for it? I dont know if they are any good?
  2. mitchsfab
    mitchsfab
    They are not so bad. I've done a few of them. Well actually its a pretty good set up for the money, even at $185.
  3. Hitchhiker
    Hitchhiker
    all black wires? no thanks.
  4. 56 ford custom
    56 ford custom
    from Socal
    By no means its no show car....but I want it clean and reliable. Im not sure exactly how many circuits I need
  5. 56 ford custom
    56 ford custom
    from Socal
    All black looks better then a bunch of colors....just me...
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Do you mean every wire is black ? That would not be good, no way to ever trace a problem and even installing it must be fun ! Color coded is the only way to go.
    How about a Rebel 9 + 3 kit ? Depending on how many accessories you have they are a great kit for the money. I installed one on my 27 and will also use one on my rpu project.
    Don
    Rebel Wire 9 + 3 Circuit Wiring Harness
    $169.95Buy Now
    The Rebel Wire 9 + 3 circuit wiring harness is perfect for your hot rod, street rod,custom or muscle car applications that require fewer circuits. ***embled in American from American made components, the heavy duty SXL wire is labeled every 6" and bundled for easy installation. This kit has 9 circuits for lights, gauges, radio, heater, motor, and third brake light, plus 3 open circuits for whatever you might want to add such as power windows and doors, electric fan, etc. Kit comes with easy to use instructions for Chevy, Ford or Mopar installations, dash light wire, neutral safety switch wire, fusible link, 1 1/4" rubber grommet for the firewall, 3 fuse block terminals and fuse block label.
  7. mitchsfab
    mitchsfab
    Those all black wires are ok. Because the all are labeled for what they go to about every 8"-12". Also with the black you don't have a rainbow under the dash.
  8. deto
    deto
    All black rugby: good
    All black harness: bad
  9. scibjenkins
    scibjenkins
    HAHA! Get a kit from Speedway, it's $140 for a 12 circuit (which is all you really need) and $160 for their 20 circuit setup... and you never SEE the wires if you do it right... all black wires sounds great if love making things really hard on yourself.
  10. 56 ford custom
    56 ford custom
    from Socal
    I guess its just a personal preference
  11. curbspeed
    curbspeed
    I used one in my car and it was fine. All the wires are labled and it was easy.
  12. JeffB2
    JeffB2
    from Phoenix,AZ
  13. I have used at least 5 of them and they are no more of a problem than a colored one. just pull the extra circuit from the back if you do not plan on using that circuit. if you think you might add it later coil it up and wire tie it up.
  14. tudorkeith
    tudorkeith
    I've had the ez wire kit in my car for 4 years with no problems. easy to install...real easy with the color coded wires. don't think I'd be keen on all black wires though. I'd definatly get the full size fuse box. I'd also figure out how many circuits I was going to run and get the one I needed. I have an 18 and have a ton of unused wires.
  15. gmc1941
    gmc1941
    I guess it wouldn't matter if your color blind. But I would prefer colored wires, easier to trace........
  16. bobss396
    bobss396
    All black might be okay if you can easily identify where it goes. If you have access to a wire marker system, you can make up shrink sleeves with the destinations on them.
    Bob
  17. chopped
    chopped
    The Speedway kit is the EZ just rebranded, same exact instruction book.
  18. woodbox
    woodbox
    I am currently installing one in mine, and no problem with one color....in fact prefer it, as is will look neat and tidy once all clipped into place
    Check it out!
  19. 48ford
    48ford
    How old are you/
    How are your eyes?
    The quality is top knotch,Mine is 10 years old now,but as it is all one color,and your upside down under the dash it's hard for me to see the printing on the wires.
    (but i'm an old fart.)
    They are good kits.
    Russ
  20. bobss396
    bobss396
    If you tag everything and route them in appropriate bundles, it will be manageable. I've taken old harnesses out, nailed them to a piece of plywood and "built" the new harness on top of it. That way you get the breakouts pretty close to factory.
    Bob
  21. KooDaddy
    KooDaddy
    from Wis.
    There you got your answer and OMG you answered it yourself.WTF
  22. 59 brook
    59 brook
    48ford hit the nail on the head i have 2 ez wire harnesses 1 black 1 colored . when i was younger and the eyes worked better about 15 yrs ago all black was no problem . 15 yrs later the writing is much hardewr to see and i would use the colored wire if i had to do it again
  23. Cool !
    What color are you going to paint it. Lol
    No way in hell would I use a mono color harness.
    But I usual have 100-160 wires at the big end. That's much different than only 22 of them total.
    Still wouldn't do it , EVER - even if it was free! the few bucks you save (25.00 in this case) are eaten up the first time you have to troubleshooting something.
  24. choptvan
    choptvan
    Here's the thing. It is a personal preference. But if you do it right ALL of the exposed wiring is covered anyway. I personally use painless wiring. I use the 8 circuit modular harness. I can put it in the trunk if I want. Comes with most of the connectors too. You can get harnesses that even have the switches with them already. They even have the zip ties. But I have noticed a trend with you. Ask for advie alot. Then, don't use it. And as already shown, you already have the personal prefernce for the all black kit. So my questions to you is, why even ask?
  25. cully33
    cully33
    I fitted a Speedway unit in my 32 was really simple and in the areas where it showed such as the engine bay I just wrapped it in black electrical tap.
  26. 56 ford custom
    56 ford custom
    from Socal
    I want to know what others think about the kit and what they do. Doesnt mean I have to use it. Either way...what does it matter?
  27. trbomax
    trbomax
    I guess I'm older than I thought. Ive always had a spool rack on the wall with 30 different colors/sizes on 100 0r 50 foot spools.Useing this ,I always made my own for cars,boats,even my KW motor home. I'm too old school to buy into someone elses plan for my wireing,but thats just me.
  28. rustednutz
    rustednutz
    from tulsa, ok
    Trying to troubleshoot an all black harness is easy, you know the problem is with the "black wire". Simple as that.
  29. aerocolor
    aerocolor
    from dayton
    i used an all black harness in my `29 last winter and it was harder to keep track of the wires with my old eyes but the finished product looked nicer and hid better. I`d probably do it again..
    And I paid $75.00 for it at a swap meet(9 circuit) new in the box.
      376.1 KB
      404 KB
      482.6 KB
      452.1 KB
  30. burnout2614
    burnout2614
    Neither is "easy" but either one works if one is confidant in their abilities. peace
