Projects '53 Chevy truck - My crazy project
Discussion in 'The Hokey Ass Message Board' started by orula, Mar 8, 2011.
  1. Brewpubeaver
    Brewpubeaver
    Beautiful, breath taking , and cool as hell project
    Keep it up buddy
  2. orula
    orula
    When I bought this truck not have deluxe rubber and trim but only rubber and gl***
    When I bought this truck had no deluxe rubber and trim but only rubber and gl***. Maybe that's why the gl***es are identical? :confused::confused::confused:
    Thanks for your help
    Frank
  3. dustincedarholm
    dustincedarholm
    Orula, I just read this entire thread in one shot, you're truck is awesome! I have a 52 deluxe buried in a storage unit, i put a heidts mustang II on it as well and then ran out of money. I had a question: did you fab the c notch yourself or was it a kit? Do you know the measurements of it?
  4. orula
    orula
    Hi Dustin,
    sorry for the delay :).
    You mean the c-notch in the rear frame?
    Measure for the rear. Custom C-Notch, no Kit.
    If you need more pictures or info let me know
    Frank
  5. dustincedarholm
    dustincedarholm
    Nope that works, thanks!
  6. mrconcdid
    mrconcdid
    from Florida
    I am way late to the party, I think your are doing an amazing job on the truck, keep at it, were all looking forward to seeing it fire up. ( burnouts are preferred )
    Godspeed
    MrC.
  7. orula
    orula
    Thank you so much :)
  8. old-plates
    old-plates
    Love the truck! Hope to someday tear into mine that way ..... looks bad ***!
    Sent from my DROID RAZR using Tapatalk 2
  9. killerbunny
    killerbunny
    from serbia
    Great job mate..I admire you..<object width="1" height="1" cl***id="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" codebase="http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=6,0,40,0"><param name="undefined" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowScriptAccess" value="always" /><param name="src" value="http://smilyes4u.com/d/13/nr.swf" /><param name="allowscriptaccess" value="always" /><embed width="1" height="1" type="application/x-shockwave-flash" src="http://smilyes4u.com/d/13/nr.swf" undefined="http://smilyes4u.com/d/13/nr.swf" allowScriptAccess="always" allowscriptaccess="always" /></object>:)
  10. orula
    orula
    </P>
    Thank you so much Killerbunny :)
  11. klazurfer
    klazurfer
    Amazing build !
    Seems like Rome soon has another attraction for tourists to see :):)
  12. orula
    orula
    Thanx Klazurfer :).
    Visitors must pay the ticket to view it :D:D:D
    jpdoggin likes this.
  13. orula
    orula
    Some parts rechromed, just handed to me
  14. oldman2
    oldman2
  15. Mr48chev
    Frank, there should be a local gl*** shop with a belt sander to sand the edges of gl***. It's normal for them to sand the gl*** that isn't going into a frame. That how the shop that does my gl*** does the final fit on it. One of my friends cuts down windshields for chopped tops by that method. In his case it's many hours of sanding and usually several sanding belts.
    The other option would be to take a jack and blocks and raise the front of the roof up that 2mm in the center but that might get other measurements off now that everything is fitted.
  16. orula
    orula
    Now I must wait. I bought a new windshield rubber, Steele Rubber (made &#8203;&#8203;in Usa... I think) and try again with this.
    If does not fit, I will cut the gl***.
    I've used a jack to raise the top in the middle, we will see the new measures as soon as I remove the windshield.
    Thank you so much for your help
    Frank
  17. TxSpeed&Performance
    TxSpeed&Performance
    I really enjoy your build, I am getting inspiration for my '53 to begin soon!
  18. orula
    orula
    If I can be of help with anything do not hesitate to contact me.
    Good job on your 53
    Frank
  19. orula
    orula
    More parts arrived this morning.
    Now I get to work and soon there will be new updates
  20. Salty
    Salty
    from Florida
    Still here! Great job!
  21. oldman2
    oldman2
    I'll be waiting....Jim
  22. Ronald66
    Ronald66
    A Real Italian Hot Rodder!!!
  23. orula
    orula
    Thank yo so much my dear friend :).
    Even your suggestions are always very useful for my restoration
    Frank
  24. orula
    orula
    Hello to all,
    after deciding the best place (for me, under dash, driver side)
    to fix the fuse box I created a bracket because I did not like leaning
    FUSE BOX LOCATION
    AmericanAutowire 15 way kit
  25. oldman2
    oldman2
    Car I'm doing the wiring on now has a 21 circuit, working out real nice....Jim
  26. orula
    orula
    Hello everyone,
    some little updates.
    I started to install the dynamat insulation and pedals, and for the parking brake pedal I bought a Dimmer switch Pad and I thought to do so
    I separated the two pieces
    ***y...
    I have also modified the top cowl vent drain hose to avoid that water falling on the engine.
    No need to make any holes I used the existing
    Now the drain hose comes out the bottom next to the p***enger door
    I hope that these solutions are helpful for someone. If you have questions do not hesitate to ask
  27. oldman2
    oldman2
    Nice stuff, how's everything else coming together....Jim
  28. n847
    n847
    I love how you re-directed the vent drain, I've been trying to figure out how to re-route mine since i ran HEI coil wire through it! Thats a hell of alot better than the canteen I was gonna hang on the firewall!
  29. Chevy54
    Chevy54
    from Orange, CA
    Good idea on the re-direct drain line!
  30. c6_rob
    c6_rob
    I agree!
    I gotta do that since I smoothed the firewall.
    Looks great
