31 Ford
Discussion in 'The Hokey Ass Message Board' started by joeflh, Jun 2, 2012.
  1. joeflh
    joeflh
    Howdy all
    Got my first model A & just needing to know what oil to put in the engine ?
    also still looking for a original tool kit for a model A pick up.
    Thanks Joeflh
  2. flatford39
    flatford39
    It is used to straight 30 weight.
  3. The37Kid
    The37Kid
    Non detergent, you don't want old stuff getting loosened up.
  4. If the previous owner was using non detergent continue with it. What was the previous owner using?
    Charlie Stephens
  5. U-235
    U-235
    Yes, if you can, find out what the previous owner used...
    once bought a 49 Plymouth (driver for work)...thought I do the old car some good and changed the oil the 1st nite of ownership. Changed to a nice detergent oil to clean her out.....well it loosened up all the sludge. I got to work the next day, but I didn't make it back..! threw a rod right out the side of the motor and had to pay to hall it off to the junk yard. Most likely the detergent lossened up the sludge, blocking the oil p***ages, no oil to the bearings...thrown rod....it was white hot sticking out the side of the block !
  6. ironandsteele
    ironandsteele
    I use valvoline straight 40 with zinc
  7. joeflh
    joeflh
    Thanks to all of you that replied to my ? it was a big help
  8. Grnegg
    Grnegg
    I run Shell Rotella T in my "A". It's superior EP properties help preserve the babbitt bearings. My engine is a fresh rebuild though...
