Ford/Y Block Guys
Discussion in 'The Hokey Ass Message Board' started by Johnny Suede, Jun 13, 2012.
  1. Johnny Suede
    Johnny Suede
    I found a 292, and am looking to put it in my 53' Mainline. The Flathead is shot... Can anyone tell me what mods this is going to take. Done it before?
    I've read a lot of other posts, but some of the links have expired.
    I've also read there is a Hot Rod article about this same swap, but cannot seem to find it. Any links or info on this?
    Any advice would be greatly appreciated, except suggestions to go with another motor; I have my heart set on this Y-block:D
  2. 4rod
    4rod
    I suggest you take measurments for the engine mounts, and tranny. Then if you haven't make sure you swap the 6 volt to 12 volt. Need new radiator, and small stuff, might as well change out the points for electronic, also, put in a newer coil(12V)...Y blocks forever is a great reasource
  3. ken1939
    ken1939
    Yes Mummerts is the Y Block Man. I am getting his conversion kit for the 292 to run a C4 on it. As mentioned some of the small stuff will have to be changed, but its up to you wether you want to change the trans. I would, just to handle the engine better. Mummerts will know the best way to do it.
  4. 65COMET
    65COMET
    What I ran into on my 52 Mercury was the oil pan,cross member interference,notched and reinforced the cross member and fabricated side mounts and did away with the 'steadyrest'.I'm using a T-10 four speed so just had to modify the trans cross member and build a trans mount. ROY.
  5. George/Maine
    George/Maine
    Good thing about a y block on a rainy day you can change points in it from inside car.
    You need truck oil pan timing cover front engine mounts dropped tie rod.Y not 302v8 better choice.
  6. 65COMET
    65COMET
    The truck oil pan still hit on the crossmember,I have three different types of pans,NO WORKY without modifying the crossmember.If you raised the engine enough to clear then the trans hits the tunnel enough that you would need to make the hump larger. ROY.
  7. Blue One
    Blue One
    from Alberta
    Mummert may be the Y Block guy, but he is just selling you the conversion kit from Gene at Flat -O- Products. He makes the kit.
    I found it far easier to order directly from Gene at Flat O, he is easier to get in touch with than Mummert.
  8. Johnny Suede
    Johnny Suede
    I found most everything I need; except, still need to locate a truck timing cover.
    Thanks for all the great advice everybody!
    -Johnny
