62 Thunderbird 390 oil level issues "HELP"
Discussion in 'The Hokey Ass Message Board' started by ratman, Jun 16, 2012.
  1. ratman
    ratman
    Hi Guys I need some help. This is my first Ford V8 ever and I am a bit lost at the moment. I have a 62 Thunderbird with a 390 and today we decided to change the filter and oil.
    I drained the pan and did the filter while my daughter refilled the engine while I made us a coffee.
    When I returned she said she needed more oil, This was my WTF moment as she had managed to put 10 litres ( 10 US quarts) in and it was still about 1/8" below the full mark.
    Clearly the motor is fitted with the wrong dipstick. When I measure the one I have it is 20 1/2" from the top of the cap (where it stops on the tube) to the bottom of the dipstick. it has the part number C80E-6750-B which from what I can see belongs on a 428.
    I think it should measure 27 1/2" on where I am measuring it. Can somebody help please.
    cheers
    Peter
  2. ratman
    ratman
    I guess the other question is how long should the dip stick tube be as that will effect things if that is incorrect also.:confused:
  3. bobss396
    bobss396
    You would need a matched dipstick and tube. Probably any 390 or 352 set up would do it. You just may have a 428 stick. Which you can calibrate to get you going. Drain all the oil.. bummer.. add 4 quarts and let it sit to settle. Mark the stick with an electric pencil. Add the last quart and do the same thing, providing your 'Bird takes 5 quarts. Check the manual for that.
    Bob
  4. mikemo
    mikemo
    ***uming you have not started the engine since the oil change, I think you should drain the oil, then add 4 qts. start engine to fill filter, shut down, let settle and mark stick to show 1 qt. low, add 1 qt. and mark to show full. This will get you going until you can determine what's up with the dipstick.
  5. sunbeam
    sunbeam
    My old motors manual sez 5 qt 6 with filter I'd put in 5 qt and cut the tube to make the dip stick read right.
  6. tommy
    tommy
    I had the same problem with a flathead. I finally got a matched pair that came out of the same motor and used them. They probably make a Chinese chrome dip stick kit for your engine for very little money. The stick has to match the tube for an accurate reading.
  7. slickhale
    slickhale
    from Phoenix
    the C8OE dipstick is for a cobra jet in a mustang so its shorter, put it on ebay and some resto-nut will buy it
  8. ratman
    ratman
    Thanks for the help. I will order a new stick and tube from Mac's antique auto. But in the mean time I will have to make something up until it arrive's as the 428 stick is way to short.
    I picked this car up 3 weeks ago and drove it a 1000 miles home with 4 quarts to much oil in it :eek:
    That explains why the oil looked a bit frothy on the stick when I checked it half way home.
    Again thanks for the help, The Hamb is a great place.:)
  9. 432bullet
    432bullet
    Just drain it and put 6 qts in it and mark the dip stick, Thats what a stock 390 needs. If you are running a bulit FE then you should run 7 qts with a stock pan to allow for the slow drain back in the heads. You don't need another dip stick.:)
  10. garcoal
    garcoal
    my stock 428 in a 66 bird takes 5 qts
  11. Wolfman1
    Wolfman1
    My 62 t-bird owners manual says 5 quarts without a filter change 6 quarts with a filter
    I bought the Macs tube and dipstick and thought it was poor quality, didn't bother using it.
