speedometer cable?
Discussion in 'The Hokey Ass Message Board' started by bbd1, Jun 17, 2012.
  1. bbd1
    bbd1
    FNG
    I have a 37 ford speedometer and a muncie 4 speed trans. What speedometer cable should I use? Would the cable for the 37 work with the muncie? Thanks
  2. Deuce Roadster
    Deuce Roadster
    Yes ... a stock original type 37 Ford speedometer cable " in good condition " will work. Or it did in a 40 Ford :D
  3. e1956v
    e1956v
    Alliance Vendor
    If length is ok it should work, both the Muncie and the stock 37 trans used a 7/8-18 nut. If you need need a longer cable and housing PM me or email through our web site and we can make a new one any length you need.
  4. Mr48chev
    I'm not positive what threads the speedometer end has but you should able to walk into the local NAPA and buy a "universal" cable and housing the right length off the shelf or have them have it there the next working day. You will need to know the length and ends you need though. A sample is good to take along as then you can tell them you need "one like this but ** inches long".
  5. bbd1
    bbd1
    FNG
    OK Thanks , Thought so from what I read. Just wanted to double check. again thank you
