460 in '37 Ford - Big Enough Radiator?
Discussion in 'The Hokey Ass Message Board' started by Scumdog, Jun 20, 2012.
  1. Scumdog
    Scumdog
    At some stage i'll need to figure out how I'm goign to keep the 460 in my '37 cool enough.
    The 460 water-pump shaft clears the stock radiator by about 3/4".
    And as the front sheet-metal is all stock I cannot go any wider/higher.
    So how likely to keep the big-block cool is the stock-but-recored radiator??
  2. joee
    joee
    call the radiator people
  3. sunsetdart
    sunsetdart
    Rule of thumb is you need for every cubic inch, you should have the same in square inches in finned core size.
    Example.........if the motor is 460 c.i. you should have around a 21x21 finned are for the core. 21 x 21 = 441 which is close.
    This is not etched in stone either, just a plan to help figure out cooling.
  4. FrozenMerc
    FrozenMerc
    Spend the extra money on Copper and Br*** and give these guys a call. They will build it to your specs.
    http://www.usradiator.com/
