I am looking at buying a 34 sedan delivery but I need to know what parts from a 34 ford sedan will fit eg. fenders front and rear ,running boards,hood doors , dash etc.
The rear fenders are SD only as is the rear pan, door. The rest is the same. The car was made from a tudor sedan and only the rear changed.
If I am reading this correctly, you are saying that a '34 Sedan Delivery was made from a Tudor body by filling the rear windows and adding a door? That was the case for '32 but '33/'34 are a unique body. If I remember correctly, the front doors might be the same as a Fordor Sedan, but the body from behind the doors is SD only. It is correct that the rear fenders are different than a regular sedan and the short pan that goes under the back of the body is nearly impossible to come by. Fenders and the pan are available in fibergl***. Unlike the regular sedans and other p***enger models, the gas tank uses a screw-in filler neck like a pickup. Here is a '34 Sedan Delivery that my Dad owned for 25 years. It was restored for him by the late Don Thelen. If you compare the body to a Tudor Sedan, they are clearly not the same.
I believe the rear fenders are very close to those of the Victoria, as is the gas tank. Keep us posted as to what you do with this purchase.
