Customs My 1950 Shoebox, unconventional build
Discussion in 'The Hokey Ass Message Board' started by swest8763, Apr 30, 2012.
  1. swest8763
    swest8763
    Now back to story line :p
    Frame was notched, needed to get the rear done! Built my own 4 link, diff plate (by my man Craig), had to have some bungs custom made (thanks jeremey) and now to do 6 different mock ups in the middle of July! It was so hot out a lot of my work was done between 11pm and 4am!
    2" box tube (0.25 wall) lower links...why? I got them off craigslist for $10!
    1 fixed, 1 adjustable...2.5" ends
    Diff plate by Craig...
    Top bars are 0.25 wall with 1 fixed, 1 adjustable 2.5" ends
    Pinion Angle test...notice my 2 boys came out to drop the jack for me...still in their pjs.
    <embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf" flashvars="file=http%3A%2F%2Fvid48.photobucket.com%2Falbums%2Ff234%2Fkiddkutt%2F50%2520Shoebox%2F2011-07-17_12-02-47_765.mp4">
  2. AV88
    AV88
    Ok I think I know now where your heading with this and I half understand your doing it all a little different the pics of the chop look good
  3. swest8763
    swest8763
    Thanks again for the words of encouragement. If anyone has every watched back from the dead II or any interview with Ian Roussel, he talks about looking at a build like a piece of art...I've always built buy feel. It works for me...especially since this is my first bottom up build with no help. The first time I sparked a welder was on the door handle of this project in 2009...so I'm fumbling my way through it like a 16yr old in the back of a car with the prom queen :D
  4. GassersGarage
    GassersGarage
    Er,,,,,,,,are those the wheels you're going to run?
  5. swest8763
    swest8763
    1@1
    I wanted it low and I wanted to have options...so I've used a bunch of different rims for mock up. I've used 15" with 75 series, 18" with 55 series and 20" with 35 series...so no...those aren't the actual rims, technically they are for a front wheel drive car...but I basically traded each set to keep trying different variables...
    I will have 2 sets of wheels for the car...each depending on how I feel that day :). I go to traditional shows & cruises as well as mini-truck & custom shows...so it just depends what I am feeling
  6. swest8763
    swest8763
    So once the suspension was figured out and mocked up completely it was time to put the body back on and start to put it all together.
    The S10 front clip caused a need to change the front mounts, besides those things are a little light and the guy that had the car before me did some "amazing" work on them and I couldn't find a good way to fix them...so I cut them out. Also with the ability to lay the car out with air came the ability to hit the firewall with the tires :eek: No problem thats what a sawzall is for. There are a lot of little ways to tub the firewall, but I wanted something that wouldn't be too deep into the floorboard and looked more natural to the car.
    Old mount and part of the firewall cut up to clear tires
    New mount built, extended it as well because S10 & original frame arch up differently
    Even customizing it, I wanted to keep the overall design consistent with its original but slightly stronger.
    I recessed the firewall to the ridge (see below)
    P***enger Side
  7. xxzzy999
    xxzzy999
    If you had not cut off the front mounts from the body you could have welded a 2"x2" section of sq tubing on the side of the frame up to the mount with a flanged bolt welded to the top of the tubing... that's what I did (see pic below... it's just tacked in place for now).
    Good Luck!
    X
  8. swest8763
    swest8763
    I like that setup. The mounts were in pretty bad shape from the previous owner so cutting was safer. So you are flush mounting the front or will you be using any bushings in between?
  9. xxzzy999
    xxzzy999
    I'll make some thin rubber pads like were on the mounts originally.
    X
  10. swest8763
    swest8763
    Well...its Friday and I have a little time at work :) So here are some new pictures.
    So earlier I showed the terrible channel & floor
    ORIGINAL:
    It wasn't braced well, level or straight.
    Since the floor was being built by stick, roof was chopped and the car was on air...I wanted to make sure my lines wouldn't flex and the Shoebox is notorious for the the door sagging. I cut anything that looked rusty.
    First I rebuilt the lower front pillar by sliding a 2.75"x1.5" box inside the factory pillar and rebuilding with new material.
    Next I needed to close the gap between the Rocker (new from EMS) and the raised floor frame. So I used some 11 gauge drops (cut s****) I picked up from my Steel Guy. ***Did I ever mention that I buy 99% of my metal as s**** weight drops? Thats why I've been able to over engineer everything! I may have $200 in steel other than the stamped panels from EMS via Mac Auto!
    So here is what I did for the door sill. 11ga, 4" wide and hand formed for proper door closing.
    Over layed the rocker...
    **notice the inside floor is not paralle to the door. The curve of the bodyline need to be right so the floor was built square and then began spacing at the "B" pillar until the curve was correct. Plus it going to be a great place to build the door poppers in...or I have room if I decide to suicide the doors.
    Finished the front behind the fender...
  11. swest8763
    swest8763
    Car was missing all of the inner fender pieces and the original owner used some angle iron and flatsheet. It wasn't going to give me a clean look or the room I need to lower the car. So I started the mock up of the top of the fender well. Once everything is mocked up, I'll break & bead roll panels to make I nice finished engine bay. And yes, its a 350 sbc...came with the car, I'm still hunting for the final motor to build. But I cleaned this up just in case.
    But now the lower mount for the Hood Hinges was blocked...so I cut!
    Its on at the firewall...but braced with a 2x4 at the front...well it time for s**** pile...a couple bends and holes later...
    Now its pretty sturdy...and level
    Now I set the fenders and I've decided to build box tube mounts with welded nuts. They'll be hiden with the finish panels.
    I'll get more up to date pictures soon.
  12. mattcrp1
    mattcrp1
    I like the way you clipped the frame, got any close ups or pics of the jiging to set it before welding?
    thanks
  13. Buddy Palumbo
    Buddy Palumbo
    Lots of good , solid work ... keep it up !
  14. Johnny1290
    Johnny1290
    wow. subscribed!
  15. Shawn F.
    Shawn F.
    Lookin' good! Subscribed as well! Post some pictures of some steel wheels and WWW's!
  16. swest8763
    swest8763
    Jiging??? It was really just from the hip on jiging.<O:p</O:p
    <O:p</O:p
    1. We found the spot on the 50 frame that was a) closest to the width of the S10 b) behind the firewall & under the body so it was out of sight.
    <O:p</O:p2. Measured from that point forward to the center of the spindle so we knew how much of a clip we needed to work with.<O:p</O:p
    <O:p</O:p
    3. Used that measurement to cut our clip (we shaved 1.5" for adjustment). Then braced the 50 frame about 5" behind where we planned to cut and cut the stock front off.<O:p</O:p
    <O:p</O:p
    4. We actually just sat the frame & clip on the hubs and leveled the frame, my garage floor has a 1/2 slop forward over 20' but that wasn't a huge concern because of the Air Ride that was going on it would be made up for any difference. But we wanted the frame as level as possible.<O:p</O:p
    <O:p</O:p
    5. Using 114" on center wheel base we just squared out the frame. To square it we measured 114" center, then cross point from the center of of rear notch to shock mount hole on clip and body mount under door to frame horn of clip.
    ***I'll look for better close ups.
  17. swest8763
    swest8763
    Wide Whites are going to cost me $800...I bought the mockups for $100! There won't be any WWW until its finished because if I'm spending money...its on the new fenders patches first! I found some rust on the fenders and I'm going to cut them apart now :)
    Thank you all for the encouraging words! I'm just a hobbiest, but apparently a damn good fabricator for an accountant :) At least that what my buddy said.
    Its all in mock right now, I've just reworked the roof on the driver's side because there it looked pinched and had a flat spot. But the cool thing is it feels perfect now, but kind of looks like Frankenstein.
    It is going into FULL MOCK this weekend hopefully because it will be at my best friend's grand opening for his body shop. I'll put a bunch of better pictures from that and throughout the process of full mock.
    This weekend is the Road Rockets' Rumble in Indy...my favorite show of the year so I'm hoping for inspiration!
  18. mattcrp1
    mattcrp1
    Thanks for the reply, great info.
  19. flamingokid
    flamingokid
    Looks great!! Subscribed...
  20. swest8763
    swest8763
    Well...I've been horrible about posting for the last 4 months. The summer in Indiana was the driest and hottest that I can remember, garage work slowed a lot and when I was out there anything more than a few hours would put me out of commission for the rest of the day. That plus a new position at work has put me in 4 places at once. But I'm uploading some images so I can post som progress to get caught up.
  21. ffr1222k
    ffr1222k
    Looking forward to your progress pictures
  22. TrioxinKustoms
    TrioxinKustoms
    from Romney, WV
    I was wondering why the floor looked so close to the dash..
    amazing craftsmanship, I was confused on the over complicated look of the chop
    But I cant wait to see it rolled outside.
  23. manyolcars
    manyolcars
    What are you going to do for the back window?
  24. motoandy
    motoandy
    from MB, SC
    Do you have a full side shot of the roof, chop?
  25. sr808
    sr808
    I like the way this is going. Subscribed.
  26. swest8763
    swest8763
    Its roomier than it looks...I had a buddy get in the driver seat to check and he's 6'5"...he fit, couldn't see out the window but he fit :cool: I'm only 5'8" so its real roomie for me ;)
  27. swest8763
    swest8763
    Working on a mold from the original window, going to have it formed by either a company in town or ship it out.
  28. DadsBlueFord
    DadsBlueFord
    from Hayden, ID
    How did you make those fenderwells?
  29. roddinron
    roddinron
    ^^^^^ x2!
