49 Suburban carryall air ride question
Discussion in 'The Hokey Ass Message Board' started by 48ChevBagged, Jun 22, 2012.
  1. 48ChevBagged
    48ChevBagged
    from Valdese,NC
    Just aquired a 49 chevy suburban carryall. I am wanting to air ride it. Just curious if anyone else has theres bagged and would mind showing me some pics so I can get some ideas of how to do mine. I mainly just want to see the rear pics. The front already has a mustang II so I am just gonna use shockwaves for the front on it. Just want some ideas for the rear. Any help will be appreciated. Thanks
  2. EnragedHawk
    EnragedHawk
    from Waco, TX
    Here's mine (panel though):
    If you're wanting to see rear frame and suspension pictures, mine is hardly a good example. S10 frame and ****py two link set up, not really HAMB friendly and not exactly well done (I plan to re-do it).
  3. fatty50
    fatty50
    Look up mikeintulsa he's doing exactly that with lots of info
  4. fatty50
    fatty50
    He hangs out on the ADtruckers sub forum also
  5. 48ChevBagged
    48ChevBagged
    from Valdese,NC
    EnragedHawk what are you doing your bare metal work with. Looks good.
  6. EnragedHawk
    EnragedHawk
    from Waco, TX
    Man, I have changed from one thing to the next trying to find the best way to go at it. Most of that driver side was done with 40 grit sanding pads on an orbital sander, but they don't to squat on the pitted sections. I traded over to a wire cup brush on an angle grinder that seems to be doing wonders on the roof. Vinegar and the occasional Rust Cure seem to handle the pits pretty well.
  7. EnragedHawk
    EnragedHawk
    from Waco, TX
    Here's the driver side before I really got going:
  8. Sssingo
    Sssingo
    from London
