Hot Rods 50 days to build a roadster, why not?
Discussion in 'The Hokey Ass Message Board' started by redbeard, Jun 27, 2012.
  1. redbeard
    redbeard
    I got some metal in my eye, so I have to take a break, so I figured I would share my build so far.
    So the story is I put on a Roadster Run and a Reliability Run each year and it is coming up on July 15th.
    more info on that here.
    http://www.jalopyjournal.com/forum/showthread.php?t=697784
    At any rate, I sold my roadster to put a down payment on a house with some land and a shop. Something I never have had. Every car I have built has been outside in the driveway.
    Under a car port or in the dirt.
    Here is the car I sold. :( Hard to do, but it went to a good home in Oregon.
    Bottom line is I really did not want to be with out a roadster for my own run................
    So, I sold that car on May 26, and that same day it sold I went and picked up this 29 roadster body and frame with ***le.
    I was building it with the Model A frame, which was twisted about 1 1/4", which
    I could fix.
    but then I was offered an original 32 frame, for a great deal. thanks Rick
    So I gather up some parts from around the yard
    Old chromed 33 axle, with 32 wishbones, and spring. and a 33 rear axle.
    the 33 rear axle actually had a stripped key way on one axle so I started searching for another.
    And came across a 34 rear end out of a 3 window. We pulled it out an I got it for a great deal. When I get home and check the ratio...3:54 unbelievable. I was happy to say the least.
    Then I found another cowl to fix the firewall that had been hacked out for a mid engine back in it's race car life. The car was also channeled, but I found subrails from another freind.
    Drilled out all the spot welds, and fit it into the new roadster
    Then after I spot welded it back into the car, I had to repaint the areas that were welded.
    what to do? I didn't have time to do body work and repaint the whole car.
    So I taped up some old timey scallops. In my dirt "paint both" haha
    yes I am a hack.
    Then I robbed the motor and transmission out of my 33 coupe. it was hard to take apart a
    running driving car, but sometimes it has to happen. the 33 is getting an Olds and lasalle any way.
    Now along the way I have been helped out tremendously by many of the hot rodders round here, and in particular by my budy Mike Sauers.
    He found me the 32 motor mounts and anti chatter rods. He had a cut down 34 torque tube
    to fit the 32 frame. He had a 32 sector housing so I can use my 33 steering box. And some BLC headlights.
    And his knowledge about this stuff is priceless. thank again Mike.
    So yesterday some friends came over and we set the body on the ch***is for the first time
    and it finally is looking like a hot rod.
    My budy Matt Seret worked his magic fixing my radiator so I can run a fan, thanks Matt.
    I still have a long way to go.
    But hopefully my eye will heal quickly and I can get working on it again.
    And I hope to drive it on this years run.
    with 17 days left I think I can make it. Or at least die trying.
    wish me luck, I need it.
  2. LSGUN
    LSGUN
    from TX
    So awesome, you can do it guy.
    Yay, 1000th post!
  3. 60galaxieJJ
    60galaxieJJ
    Damn this is gonna be kool to watch
  4. madpole
    madpole
    looks like it is coming along great! going to be a cool hot rod. it helps having a well stocked yard.
  5. Salty
    Salty
    from Florida
    Eyes heal quick....for a standard chunk of metel with a rust ring that they have to bore outta your skull....usually bout 48 hours....
    that said, blow the metal outta your hair next time (thats how i got my metal in my eye....was wearing a hood, when I took it off all the dust fell in my face)
    Build looks flippen sweet! wish I could have gotten mine done in less than two months!
  6. tinmann
    tinmann
    Cool build. You can do it. Call in the calvary if you have to.
  7. KustomCars
    KustomCars
    from Minnesota
    Sweet! Keep us updated!
  8. -Brent-
    -Brent-
  9. Don's Hot Rods
    Don's Hot Rods
    from florida
    50 days ! You have guts, my friend . :) We built one in 88 days one time and we were very burned out at the end .
    Coming along great and I hope your eye heals ok.
    Don
  10. coupeHEAD
    coupeHEAD
    Looks great Dave. Hope your eye heals soon.
  11. sierra rod shop
    sierra rod shop
  12. draggler
    draggler
    You can do it,metal in the eye several times here as well, it will heal quick as stated.
    car looks good by the way!
    Like the dirt shop too!
  13. MrHavard
    MrHavard
  14. Deuce Daddy Don
    Deuce Daddy Don
    Looks good ---So far!!---Hang in there!
  15. It is shaping up quite nicely!
  16. gnichols
    gnichols
    from Tampa, FL
    NICE scallops, too! Gary
  17. bridger
    bridger
    It's coming along well , good luck with it
  18. thunderbirdesq
    thunderbirdesq
    That kicks *** man, as a recent coupe owner, I'm dreaming of a new roadster as well. Nice job!
  19. seabeecmc
    seabeecmc
    Perhaps the cavalry would more ***istance than those religious people. Ron
  20. motoandy
    motoandy
    from MB, SC
    Nice work. The 33 is awesome also. Look forward to a side shot of the new roadster. Cool style on the scallops.
  21. MrGasser
    MrGasser
    from DETROIT
    What's up with the rusty coupe body on the dolly in the last pic?
  22. redbeard
    redbeard
    That belongs to a club member in LA
    next up on the chopping block
    I have made progress, but I'm too busy to take pics.
    Drive shaft shortened
    Rear end is mounted and brakes plumbed
    Half way done mounting wishbones.
    half way done building a 32 pedal box from scratch
    steering done
    to much to list what needs to get done.
    back to work
  23. Tom davison
    Tom davison
    from Phoenix AZ
    Excellent roadster that you sold, perfect. Glad you realized other dream, your home. All the best to you with your next dream, the '29. You are the epitome of the hot rod spirit.
    This is the best topic I've read here in a long time. You are ********. I'm anxiously waiting for your update.
  24. Race City Rodz
    Race City Rodz
    I like the paint!
  25. gassercrazy41
    gassercrazy41
    wow. great work. can't wait to see the updates
  26. Great story.....best of luck on getting it ready...
  27. adam401
    adam401
    Cool build. Your 34 5 window is PERFECT.
  28. shane85
    shane85
    sweet car man
  29. gonzo
    gonzo
    Very nice. Did you pinch the frame on this car, or your old roadster? If so could I get some details? Thanks.
  30. lowtruck
    lowtruck
    from Omaha
    Wow, that looks fantastic. If this one comes out as good as your old roadster or that coupe, it's going to be a total bad***. Keep it up.
