History Firestone Deluxe Champion RACING ONLY Tires
Discussion in 'The Hokey Ass Message Board' started by NealinCA, Jun 17, 2012.
  1. NealinCA
    NealinCA
    I am looking for some history on a pair of Firestone Deluxe Champion 5.50-16's that I just aquired. Printed on the sidewall is:
    DESIGNED FOR
    RACING ONLY
    MIN. INFL. 36LB
    MAX. INFL. 55LB
    The tires are new, never run...but quite old. I am curious when they were made and what they were intended for?
    Any info would be appreciated.
    Thanks,
    Neal
    kidcampbell71 likes this.
  2. Carter
    Carter
    What is the tread like on these?
    Any other numbers on the sidewall?
  3. Carter
    Carter
    Did you try a patent search on the patent numbers? I can't read the second one.
    Edit: Looks like no good on the patent #'s. Just general late 30's, early 40's tire construction and design patents from Firestone.
  4. NealinCA
    NealinCA
    The only other markings are Made in USA and what I ***ume to be lot numbers, 003029SD and 003387SD. The tread looks like a normal street pattern...
    Neal
  5. Dont know anything about them. But, man, they are cool !! Heres a bump.
  6. NealinCA
    NealinCA
    Thanks...hopefully somebody knows something about these tires.
  7. NealinCA
    NealinCA
    BTTT for the Monday morning crowd...
  8. sodbuster
    sodbuster
    from Kansas
    Have you PM'd Josh Shaw? He's sorta' a tire guru/collector of race tires.
    Chris
  9. silent rick
    silent rick
    i'll have to take a closer look at the rear tires on this car.
    i thought they were just street tires that were grooved by someone
  10. NealinCA
    NealinCA
    Thanks for the suggestion...I sent Josh a PM.
    Any others in the know?
    Thanks,
    Neal
  11. Louie
    Louie
    from NJ
    Almost bought those but shipping would have been a killer.Good score, I bought a ton of great parts from those guys at great prices
  12. NealinCA
    NealinCA
    We were in the space right next door with Myke's 3W...I would have liked to have met you.
    Neal
  13. Carter
    Carter
    Those are not regrooved. They came that way. Been looking for a usable set for years. The pair I have are pretty well shot.
  14. Joshua Shaw
    Joshua Shaw
    They are racing tires. Firestone made them for a variety of different applications. I have found them on sprint car halobrands being used as front tires on pavement. The biggest application would have been early sports car, we find those tires mounted on jag, mg, Austin Healy wires.. Hence the 16" size. Good find!! (the "for racing only" is the easiest way to spot real vintage tires from Cokers... Cokers say "for display only". I applaud Coker for doing this. It keeps the originals valuble)
  15. Joshua Shaw
    Joshua Shaw
  16. NealinCA
    NealinCA
    Thanks for the reply Josh...sports car makes sense. What era would you say these 16's are...1950's?
    Neal
  17. Enbloc
    Enbloc
    from London, UK
    If they were for racing I wonder if they had reinforced sidewalls or some other form of internal strengthening as from the outside they look like normal road tires.
    What gets me is the air pressure. 36psi minium up to 55psi!
    Reinforces my thoughts on how crossplys tyres are/were treated in racing situations.
  18. Joshua Shaw
    Joshua Shaw
    Yes, dead on. Post War.
    Not sure what the "Differances" would have been.. that would be a good question for Corky Coker. (He's on here.. PM him)
    In todays world it would be a "Legality" situation.. not sure if that was the case then or not.
  19. NealinCA
    NealinCA
    I just sent Corky a PM...thanks for the suggestion.
    I am wondering if the difference with these tires was possibly a softer tread compound?
    Hopefully Corky has some more info...
    Neal
  20. They look to be front runners. I don't have any old catalogs but that is what I believe they are.
  21. gnichols
    gnichols
    from Tampa, FL
    I wonder if Coker would consider doing a line of these, fronts and rears? They seem to have a more street friendly tread pattern than the grooved slicks. Gary
  22. Enbloc
    Enbloc
    from London, UK
    Just looking at these again. Are there support braces moulded into the rubber between each groove? A way of stablising the tread under heavy loads?
    I don't remember standard Firestone road tyres having them?
  23. The37Kid
    The37Kid
    I'll look through some old SCCA programs to see if any Sports Cars used them. Bob
  24. NealinCA
    NealinCA
    Yes, they do have support bars between each tread rib. That would make sense if they were designed for sports cars.
    Neal
  25. Enbloc
    Enbloc
    from London, UK
    Cool!
    Potentially these tyres could be strenghened internally and externally running softer compounds. Wow! The mind boggles.
    Maybe they don't do this under load!
    jebbesen likes this.
  26. The37Kid
    The37Kid
    I went through a book "American Road Racing 1948- 1950" by Joel Finn, it has lots of photos of Firestone equiped sports cars. Jaguar XK-120's, Allards, and a Fraiser-Nash would have 16 inch wheels. No photos are clear enough to read For Racing only, but the tread patters is the same. Bob
  27. NealinCA
    NealinCA
    I bet you are right...
  28. hudsoncustom
    hudsoncustom
    Great looking set of tires!
    The sidewall appears to be similar to the racing only grooved ascot and the indy tires, where the rubber is minimal, and barely covers the cords. With the reinforced sidewall cords, the strength of the sidewall is all in the cord.
    Nice looking tire, I've not seen a pair before.
  29. hopkins1
    hopkins1
    from bedford pa
    My Hillegas sprint car ran one on the right front at Morristown N.J. in 1953 on dirt. Bill Holland was driving !
  30. F-6Garagerat
    F-6Garagerat
    The sidewall flutes are shorter also. Here's a pic of a new one.
