my new project home,1954 ford customline
Discussion in 'The Hokey Ass Message Board' started by new54belair, Jun 30, 2012.
  1. new54belair
    new54belair
    Got the car home today after spraying starter fluid and using a jump box to get it to crank . All the lights was suppose to work ( so the seller said) but nothing does. He said the car was converted to 12v , when i went to hook the jump box up i had to hook the positive to the negative battery terminal because the positive battery terminal is hooked to the motor for ground , that goes against everything ive ever been taught, can someone please tell me why this is, also i cant find a fuse panel to check for any blown fuses. The car drove good,shifted good and stopped good,its just this electrical problem i got to take care of first. And yeah, im sure i will be asking alot of stupid question for you all to answer. Im ready to get this resto started.
  2. Puddin Head
    Puddin Head
    from Mason, Oh
    The fuses are behind the light switch or should i say part of if it's anything like my Falcon. Ford did that for a long time.
  3. motoandy
    motoandy
    from MB, SC
    Good start. Now all you lack is finishing it up! Post pics as you go.....
  4. 56don
    56don
    You might want to consider buying a new wiring harness since those old 54s had cloth wrapped wiring and it is probably pretty brittle and dangerous by now.The insulation on the wires in my old 54 coupe would just wipe off when I tried to move them around. They were originally positive ground also, thats probably why the positive wire was going to the engine block. Ford went to negative ground in 56.
  5. Rocky
    Rocky
    Classified Editor
    If the car has the original 6 volt battery and wiring it wil be a positive ground system. Nothing scary, just different from Modern 12 volt negative ground systems.
  6. choptvan
    choptvan
    My 54 did not have that. So that is different for me as well. But agreed on hte wiring. The cloth stuff will fail at some point.
  7. servi53
    servi53
    put in a new harness and wire it negative ground, cool project
  8. new54belair
    new54belair
    What's the best place to get a wiring harness,I looked and they are cloth covered
  9. new54belair
    new54belair
    Also how can I tell if its 12v like he said
  10. LostHope
    LostHope
    right on i also have a 54!!.......could it be possible that someone just put a 12volt battery in place of the 6 volt and it burned up all the 6 volt bulbs and gauges? cause basically switching to 12 volt all you do is put the battery in neg ground(which sounds like they didnt), change out all your 6 volt bulbs to 12 volt bulbs ,change generator to alternator,step down you gauges with a 12 volt to 6 volt converter and a few other things....your 6 volt starter will still work on 12 volt.......might be a possibility why none of your electrical works,....i would first start at the battery and see what it is 6 volt or 12 volt.
  11. 29tudor
    29tudor
    Cool car man. I've been looking for new cloth coated wiring harness for my 52 customline. Check out road island wiring.
  12. skoh73
    skoh73
    Join the 52-59 Ford Owner's Social Group and you will find answers to darn near anything you could want to know about your car. Do a quick intro and get ready for about 1000 new friends.
  13. bondojunkie
    bondojunkie
    ditto. also maybe look to see if someone mounted a ballast resistor on somewhere close to the dist., like the firewall (usually a good sign that it's been converted to 12v).
  14. Martino
    Martino
    I just got a 54 also that has been converted to 12 volt. There is a ballast on the fire wall by the distributor. Can someone enlighten me?
  15. Neat car, keep that tree shifter.
  16. Johncovert
    Johncovert
    Normally your points need to run at 6-8 volts....keeps them lasting longer.....the ballast resistor does that....its wired in such a manner that while you start it, you get a 12volt "hot shot" which gives you a stronger spark and helps start the car easier. Once your ignition switch goes back to the on position however, the voltage is fed through the ballast resistor and it drops.
  17. JohnnyP.
    JohnnyP.
    In this instant, is there 2 wires running to the ignition coil? One through the ballast and one from the starter solenoid?
  18. Martino
    Martino
    Yes my coil has the 2 wires your talking about going to the Ballast.
  19. JYPSEA
    JYPSEA
    from Florida
    Cool car. Do the rewire you'll love it. Try Rebel Wiring. There on the HAMB.
  20. Jalopy Joker
    Jalopy Joker
    Rebel Wiring Harness Ad in Parts Cl***ifieds here -
