Hollander interchange question?
Discussion in 'The Hokey Ass Message Board' started by flyin54, Jun 30, 2012.
  1. flyin54
    flyin54
    from modesto ca
    Hey everyone, just a quick question if one of you guys have access to a hollander database, I need a drivers side manual window regulator for a 58 Impala. The car was parked for many years and that is one of the many parts that vanished from the car. I can buy new power windows but want to stay manual. Thanks in advance, Brian
  2. squirrel
    nope, 58 impala HT and convertible only.
  3. flyin54
    flyin54
    from modesto ca
    What about a 58 Bonneville? It's the front one I need!
  4. squirrel
    The hollanders lists regulator number 703 for that application, and the Impala is the only car listed under number 703. Sorry.
  5. flyin54
    flyin54
    from modesto ca
    Well shucks, it was worth a shot. Thanks for the help Jim
  6. F&J
    F&J
    If it is a rare and expensive part, and it looks like a 2dr sedan? (that would not need a complicated regulator), you might find a manual reg in a modern car that is enclosed cable, somewhat adjustable, and have correct splines for the handle.
    I'd take a look at jeep cherokee either '96 down or the more compact one is like 97 to 01 I think. Those might have the same spline?
  7. squirrel
    another thing you can do is take out the p*** side regulator and see if you can find something that's similar from another car (like the bonneville, etc) and cut and weld enough to make it match.
    just make sure you make a mirror image for the other side
  8. flyin54
    flyin54
    from modesto ca
    Thats a thought, will have to look into a alternate part to replace the stolen parts.
  9. flyin54
    flyin54
    from modesto ca
    That is also a option Jim, maybe a newer hardtop will be close!
  10. squirrel
    you might be able to use a 58 chevy 4 dr regulator or something. It's worth looking at some and seeing what it would take to make it work
  11. flyin54
    flyin54
    from modesto ca
    The 4 door ones don't have 2 arms that cross in the middle but many other years and models do
  12. Checkerwagon
    Checkerwagon
    "The 4 door ones don't have 2 arms that cross in the middle but many other years.."
    There you go, that's how you get started solving the problem. You may be able to extend or shorten arms from another Parts Car* to fit.
    Think B & O (buick and olds) , like the B & O Railroad and P & C (Pontiac and Chevy) like... well... * Parts Car, as a rule of thumb for GM interchanges. Hollander is the friend that encourages you to think about the question.
    All the best,
    Dale
    Cleveland OH
  13. doozcoupe
    doozcoupe
    Check with Flat Top Bob at Owens Salvage.
  14. squirrel
    how about a 4 door hardtop?
