Carb help Holley 94
Discussion in 'The Hokey Ass Message Board' started by Chipman, Jun 28, 2012.
  1. Chipman
    Chipman
    from Oregon
    [​IMG][/url][/IMG]
    Can somebody tell me what the connection is in the red circle? One of my carbs has this port open, one is plugged and another doesn't have this port at all.
    Since it's in the main body I'm thinking possibly for a fuel pressure gauge?
  2. junk yard kid
    junk yard kid
  3. 40FordGuy
    40FordGuy
    Ported vacuum, for the vacuum advance.
    4TTRUK
  4. jack orchard
    jack orchard
    as others have said, this a vacuum advance source used only for Ford "Loadamatic" distributors (1949-1957). If you have stock distrubutor, you must use it or vacuum advance won't work. If you are not running the stock distributor, use manifold vacuum and plug it.
  5. Chipman
    Chipman
    from Oregon
    Thanks for the info guys! I will have to plug it since I'm using a Bubba built chevy distributor
  6. Chipman
    Chipman
    from Oregon
    Can somebody tell me what fitting to use to plug this? I got one that was the same size but the threads didn't fit. Please help save some hair, I've already pulled out too much.
