I need an exploded diagram Ford-o-matic
Discussion in 'The Hokey Ass Message Board' started by Chopshop13, Jul 2, 2012.
  1. In particular i need the diagrams of Valvebodies of a 53-54 ford, case marking 1P-7003-K.
    Now i already have the entire rebuild manual for Ford/Cruise-O-matics which has helped significantly in the rebuild process however were having problems with the valves orientation and the diagrams in the manual are not exactly the same as the transmission. close but different in many ways.
    We paid careful attention as we pulled it down, but now (as its not operating correctly) were double guessing ourselves. we've had the oil in and out 5 times, trying to problem solve using the flow diagrams and valve arrangements but to no avail.
    Help much appreciated.
    The manual we have is found here http://www.tocmp.com/manuals/Ford/19...cT/04-002.html but its not acurate.
  2. I feel your pain, bro, being as I was h***ling with a 52 F-O-Matic. You've done everything right so far, but I'd move over to Ford Barn on this one... Just my .02...
  3. Thanks.
    Ive posted there too, but you never know your luck.
