Projects Shoebox Chop.
Discussion in 'The Hokey Ass Message Board' started by metalshapes, Jul 29, 2005.
  1. metalshapes
    metalshapes
    I started by taking out the complete B Pillar, and Door Top.
    Then I drilled out the spotwelds on the Driprail under the Cutline.
    I cut the A pillar lengthwise, and I took a piece out on the inside ( Windshield Side ) and a bigger one on the outside ( Driprail Side ).
    After that I cut the C Pillar and took 5" off it, and I sliced off the side, 3" above the Driprail over the whole length of the Roof.
    I took 5 5/8" off the bottom of the A Pillar Driprail ( = 4" Vertical ).
    And mocked up the side, with the B Pillar clamped in place.
    More later...
  2. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    hey , that looks like my car, oh wait....it is!..looking good alex!:D
  3. cleatus
    cleatus
    from Sacramento
    Man that looks complicated!
    I like the shape of the side windows.
  4. HoldFast
    HoldFast
    that's a hectic chop.
  5. metalshapes
    metalshapes
    I have a way of overcomplicating ****..:D
    I try and keep the 1/4 windows as long as possible, visually.
    To try and match the Door Gl*** better.
    That is why I almost allways lean the B pillars foreward, and I keep the back corner of the 1/4 Window Gl*** sharp ( not rounded off, like it used to be...)
    Thanks guys...
  6. metalshapes
    metalshapes
    Yep, it is.:D
  7. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    im gettin all ancy now!.......im running around the house trying to find my ol lady saying,...."babe quick come here and look"........
    the rear 1/4 window looks great, i know that was a concern we talked about...and i think its gonna really come out good, hell i told you i trusted you!....let me know when its safe for me to come by and drool a little ....:D
  8. oldskool55
    oldskool55
    from socal
    id probably get to this point and wonder what the hell i got myself into.. looks good keep up the good work:D
  9. metalshapes
    metalshapes
    Some more Pics.
    Side tack welded in place.
    B Pillar tack welded in, and the corners from the B Pillar to the 1/4 Window pieced together.
  10. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    alex, you seem to be moving along pretty quickly, should i still plan on coming down to pull my dash out?...or should i just wait till your done with the car?....and if i can come and grab it when would be a good day?
  11. metalshapes
    metalshapes
    Sometime next week will be fine... give me a call.
    Or you can leave it in there, does it hold the column up?
  12. GRSMNKYCUSTOMS
    GRSMNKYCUSTOMS
    from TUCSON
    hey alex, just got off the phone with Mike.....he said you guys are pulling the 49 caddy fast back in next after mine?....whooooo that is gonna be a ruff chop,..but its gonna look absolutely siiiiiiick! fast back chops are the next "in" thing.
    oh and yeah it does hold the column, i will come by this week and we will talk it over
    looks great!
  13. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    nice...im a bit lost in what your doing, but im sure it will come together great.
    do you cut it like that to keep the angle of the gl*** in the stock position? I see the 1/4 window is shaped differently too.
    Either way, the chop looks *****en, I cant wait to see the roof come down to meet the rest of the car. :)
  14. metalshapes
    metalshapes
    Yes.
    Also because I like to change the dome as well, to loose a bit of the m*** over the Driprails.
  15. mexicano
    mexicano
    that looks real good. I haven't chopped anything but I always wondered about chops where the roof remains in one piece other than removing rear gl*** frame, I guess some can be done like that, but this looks like the real way to chop I'm guessing you're going to split the roof or roll out the crown?? to blend the countours to the doors,quarter,windshield can't wait for more pictures.
  16. Chopped50Ford
    Chopped50Ford
    Alliance Vendor
    That makes perfect sense. You dont see many of them addressing that issue.
    Nice work as said before.! :) :cool:
  17. mexicano
    mexicano
    Hey metalshapes, looking in your truck chop thread you said something about soft welds that you can hammer smoth (couldn't grasp the whole thing) what does that mean, how do you do it. where can I go other than picking your brain to learn about the process you use for the metal weld/finish part.
  18. I'd like to get inside your brain and see how it works:D .....I ve seen a lot of ways around the barn ,but thats different Man.......Ha!
  19. metalshapes
    metalshapes
    Its the type of welding that makes the difference.
    A Mig Weld is a lot harder and more brittle than a Oxy Acetylene Weld.
    You can do quite a lot of Hammering and Shaping to a Mig Welded area, but its tough to move the Metal and it might crack.
    O/A Welding heats a bigger area and it warps a lot more than Mig or Tig but by Hammering the Weld before it cools down ( which stetches it ), you counteract the shrinkage which causes the Warp.
    I'm guessing Hammering the Metal while its still Red Hot makes it stronger too.
    Sofar all the welding I've done to this car was done with the Mig.
    I still use that for Tacking everything in place, and for parts of the skin that I can't reach from the back.
    (You need to Hammer the Metal into a Die to stretch it...)
  20. pimpin paint
    pimpin paint
    from so cal
    Wow, never seen a chop where the window frames were chopped before
    the turret/roof, cool. What happens ta the cat walk behind the rear
    window? Does it get slid foward , for a business coupe kinda look, or
    flolded down **** Dean style? Kool chop!
  21. loogy
    loogy
    Very nice. I'm anxious to see the rest of the operations. It's interesting that you are taking this approach with the top. I am helping a friend do chop in a very similar way, but on a completely different kind of car. Looks good so far.
    Chris
  22. metalshapes
    metalshapes
    I've done a Chevy pretty much the same way.
    4" out of the Front and 6 out of the rear, if I remember right...
    And I layed the Rear window flat on that one as well ( I'll do that on the Shoebox too...)
  23. G Griffin
    G Griffin
    Thats a good lookin' chop!
    G.
  24. mexicano
    mexicano
    hey ,metalshapes do you have anymore pictures of the chevy I got a 51 and would like to get a better idea on how to chop it .
  25. metalshapes
    metalshapes
    Sure...
    But they are Photos, so I'll have to scan them.
    Give me a day or so.
    Later in the week I'll have some more pics of the Shoebox too...
  26. desertdroog
    desertdroog
    Dadgum it Alex. Quit making me lose sleep over not having my car in your hands yet. As usual, it looks like it will be another quality chop.
    Here is a pic of that Chevy as it sits now.
  27. metalshapes
    metalshapes
    Thanks Droog.
    We'll have some fun with yours too.
    And some more pics of the Shoebox...
  28. southpaw-customs
    southpaw-customs
    Great thread ,thanks for sharing. The shoebox is looking great.
    morebel
  29. metalshapes
    metalshapes
    Cut out the Driver side...
  30. metalshapes
    metalshapes
    After shortening the A and C Pillar, I tacked it back in.
    Cut the B pillar to size, tacked it in as well.
    Widened the Headerpanel, clamped it to the A Pillars.
    Clamped the top of the P*** Side Door in place.
    So I could check the Height of the Windshield, and how it compares to the height of the Door Gl*** ( The Windshield is Chopped 1" less than the Doorgl***, 3" instead of 4" vertical...)
    And check all the angles.
