Projects built a louver press...
Discussion in 'The Hokey Ass Message Board' started by Standard32, Jul 6, 2012.
  1. Standard32
    Standard32
    from LA
    I don't post much about projects and stuff I'm doing, and people keep telling me I should, so... I've been working on building a louver press...
    Here's what I started with...
    Look familar? Look behind the truck.
    I did a little bit and then stopped and took it to get it blasted.. I didn't want to wait until it was done, It was hard enough loading just this by myself!
    I don't really have a lot pictures, but this is what I ended up with...
    I made a removable piece to bolt it to the I-beam above and another one to bolt to the back.
    Here's a panel I punched... It's not going on the car, but I had it laying around and just figured I'd try it.
    They are the old style small ones with the rounded top...
    I may do some more work on the press, maybe add some more reinforcement to the throat sometime, and I'd like to put some studs in the floor to bolt it down too.. but, anyway, that's what I've got for now..
  2. deto
    deto
    Awesome man. I dig it.
  3. Champscotty58
    Champscotty58
    Nicely done. On both counts
  4. Gator
    Gator
    from Statham Ga
    Nice piece...
  5. Atwater Mike
    Atwater Mike
    Yuh tore out the hoss rack!
    Nice looking frame, REALLY nice bracketing onto the I-beam overhead!
    Yeah, those Pontiacs fit like they were made for it...
  6. yetiskustoms
    yetiskustoms
  7. cayager
    cayager
    pretty neat
  8. need louvers ?
    need louvers ?
  9. Bruthish
    Bruthish
    Very nice! Great ingenuity!
  10. Avgas
    Avgas
    Great result, Deuce looks perdy nice to!
  11. sr808
    sr808
    That's a great idea.
  12. That is a good way to save money. Just drive around with your torch in the back of your pickup and look for suitable material for your current project.;)
    That looks real nice. Did you check to see how much flex you had without attaching it to the building? That is a smart way to add strength.
    ~Alden
  13. jerseymike
    jerseymike
    looks good, just curious about how it works. is it just manually operated?
  14. flamedabone
    flamedabone
    Yea, but now some bozo will crash into your building cause the guard rail is missing...
    Nice work, -Abone.
  15. 62dartman
    62dartman
    Nice job man!!! Whatcha using for dies??? That front piece looks store bought maybe??? Looks great!!
  16. Atwater Mike
    Atwater Mike
    Yes, where did your dies come from, please?
  17. shoebox50
    shoebox50
  18. Standard32
    Standard32
    from LA
    dies are from Dave Williams...
    manually operated, using a pipe for leverage
    It needs the I-beam for strength...too much flex without it.
    someone stopped by the other day, sitting on the railing talking, they noticed it was cut and asked what was going on with it... I showed them the louver press...they thought it was pretty funny...
    I actually didn't take it all down though, it was just a short section taken out to add a door... and I figured it was a good use of the steel...
  19. neverdun
    neverdun
    Very nice. I like the way you took the flex out of it. Nice job on the louvers too!
  20. 24 Dodge
    24 Dodge
    Dave Williams sells the dies at Low Buck Tools And he supplys plans for the press. I built one and it works great. I have made lots of panels for my customers in Syracuse N.Y. I like your ingeniuty in making your press. Mike
  21. Standard32
    Standard32
    from LA
    laying it all out takes some time...it's gotta be right on...
    I bet doing a big panel with some shape to it will be fun...
  22. pug man
    pug man
    from louisiana
    Damn dude, that thing is awesome. Very nice work for sure......
  23. Standard32
    Standard32
    from LA
    I also picked up this old Bridgeport mill the other day. Now I've gotta figure out how to unload it...
    Anyone know about what these weigh? Judging by how it felt hauling it home, I'd guess it's gotta be a couple thousand pounds.?
  24. chaddilac
    chaddilac
    What are you using to punch them out with? I see the dies, but no mechanism to mash em together?
  25. BootleggerJim
    BootleggerJim
    from SC
    Very close to 2000lbs.....
  26. Mopar Jack
    Mopar Jack
  27. Standard32
    Standard32
    from LA
    I'm using a 2 ft long pipe, like this...
  28. Mr48chev
    Nice work but you sir are a glutton for punishment with that hand operated press.
  29. KustomCars
    KustomCars
    from Minnesota
