V12 Seagrave Engine
Discussion in 'The Hokey Ass Message Board' started by 38 coupe, Jan 15, 2011.
  1. 38 coupe
    38 coupe
    from Texas
  2. that would be on my list at least just to get in eunning if I was a few miles closer...
  3. threeston
    threeston
    why are people so quick to s**** stuff? that motor is a piece a guy like me would build a car or truck around.
  4. edinmass1602
    edinmass1602
    It's not a 900 CID engine, it's a smaller 1955 vintage 531. The engine was replaced in the truck as often was the case in the early service life of the truck. Feel free to email me any questions on Seagrave v-12 engines. Ed
  5. captain_crud
    captain_crud
    Good lord, that's so damn cheap that somebody's gotta get it! *Garage candy*
  6. 1950Effie
    1950Effie
    from no where
    I think those are Continental engines.
  7. Pierce-Arrow (w/refinements) we used to have them on our dept years ago.
  8. 1950Effie
    1950Effie
    from no where
    I think Pierce Arrow also used the Continentals. Working at a city we have two of those in older American LaFrance and Buffalo pumpers. Gas engines using dual dizzies one as the primary and the second as a backup for protection. Great engines
  9. edinmass1602
    edinmass1602
    No, Pierce Arrow NEVER used a Continental engine. The small v-12 seagrave went through 4 generations, but was basicly the same engine. The 900 CID motor was made by seagrave, according to literature at the time.
  10. Jack Innes
    Jack Innes
    I cannot find the ad on Kijiji. Does anyone know if the engine was sold? What was the price? I am not far from Guelph! Thank you, Jack
  11. yep.. not on there now, was 300 bucks.
  12. tubman
    tubman
    Listen to this guy; he has it right. I know because I have a 468 CI V12 Pierce derived engine in my '48 Seagrave Quad. When I got it, and found out it was derived from the early 30's Pierce Arrow V12, I did a lot of research. My truck has 4100 actual miles (23,000 on the pump meter), and runs great. Idles down to 350 RPM, and it can be started (when it's warm), with one turn of the hand crank. Won a lot of beers at car shows betting with guys who didn't understand the value of dual distributors and 4 coils.:D
    I wish I could find another good one for $300. I visualize a Bonneville car (don't know if the have a cl*** for it though)
    kidcampbell71 likes this.
  13. Henry Floored
    Henry Floored
    A Pierce Arrow enthusiast teamed up with A.J. Foyt and ran a Pierce Arrow at Bonneville with a V12 and Pierce Arrow ch***is. I believe the body was a carbon fiber knock off of an original `32 P-A coupe.
  14. edinmass1602
    edinmass1602
    Yup.... AJ didn't want to run it so he stuck his foot in it and blew it up before he made the first official p***. It was run out of texas by a guy named Dee Howard.
  15. gemcityrenegade
    gemcityrenegade
    Where was this $300 V12? I see things like that I call and buy. The other night I went and bought an engine an hour away at 10:00 at night. Hey you don't see $40 odd fires that often round these parts:eek:
  16. MP&C
    MP&C
    A buddy of mine has this one out behind his garage, rusting away. I's been there for going on twenty years, so it doesn't look quite as good as the picture. If someone could use it I think he'd give it away..
  17. 38FLATTIE
    38FLATTIE
    from Colorado
    Hell yes, I could use it!
  18. I have the same truck but without the rear crew compartment. It was built to Royal Canadian Air Force Specs in 1953. It is rusty but all there. I am developing plans to put the V12 in a 1947 Monarch 4DR (CDN version of the Mercury) with from cowl forward stretched 12inches and bolted to an F250 frame for pwr steering etc. I hope it is big enough to handle the wt. Another option is to use enough of the Seagrave frame to accommodate the length on engine & rad and then modify for the rear axel car frame pushup. Then buy a suitable heavyu duty rack for pwr satering and duisc brakes etc.
    The pump is also all there and valuable for the metal alone. Anyone neeed a Seagrave Pump out of a 5Ton pumper?
  19. JohnEvans
    JohnEvans
    from Phoenix AZ
    Terry: Ya better check availablty of parts for any Seagrave engine ,kinda related to hen's teeth. And priced if you can find them like soild gold hen's teeth.
    Boneyard51 likes this.
  20. I know, but the stuff is out there. Besides I don't need to drive it much...mostly just look at it and start it once and awhile.
    Thanks for the reply.
    Terry
  21. Rusty O'Toole
    Rusty O'Toole
    The Pierce V12 was one running machine. It looked like a real ty****'s scooter but Ab Jenkins set a record at Bonneville, 127 MPH AVERAGE FOR 24 HOURS in 1933.
    To put this in perspective, at the time Rolls Royce was warning their customers not to run their cars flat out for more than 5 miles or they would blow their motor. Rolls Royce top speed, 90 MPH. Mercedes Benz straight eight supercharged, 102 MPH but they warned their customers not to run with supercharger engaged for more than 2 minutes.
    It took a special supercharged Duesenberg double overhead cam straight eight to beat the Pierce Arrow record, also driven by Jenkins.
    If you wanted to go after the flathead record at Bonneville you could do a lot worse.
  22. Poh
    Poh
    from Quincy,Ca.
    Hi Ed, Im inquiring about the firing order of a v12 Seagrave..I need help
  23. Poh
    Poh
    from Quincy,Ca.
    or anybody else, I have a 62 I am trying to make a parade vehicle out of
  24. 40FordGuy
    40FordGuy
    Seagraves fire engines were a great item..our volunteer dep't had 3 of them , new in 1958. As I recall, the factory rep said they built every piece of their vehicles, except hoses, nozzles and lights.
    Someone mentioned a "Buffalo" pumper,...one of those Seagraves replaced the 1941 Buffalo they had since new. That v12 would make a really cool project, and definitely a one-off !
    Ditto, Pierce Arrow <built in Buffalo N.Y.> not using Continental engines...
    4TTRUK
  25. edinmass1602
    edinmass1602
    Hi, I was out of town at the Pierce Arrow meet. Just got back. I don't have the info here at work, but will get it to you in the next day or so. If it won't fire there are several common errors on the ignition set up. Also, the fly wheel is not indexed, thus you can put it on in the wrong spot...... 5 of them, as well as napa points that look the same but will not fire the plugs. What problem are you having? The cam lobe in the distributor is adjustible and not fixed, which also causes problems. Please give details. Ed
  26. Jethro
    Jethro
    Just started working on a 46 that we just re-aquired. The truck used to belong to the city then took a vacation , the guy that owned it p***ed away and his family donated it back to us.[​IMG]
  27. broderchamp
    broderchamp
    I used to work on a 100 foot ladder truck that had a Seagraves engine in it. One night a drunk asked why we were why we advertising Seagrums Whiskey on our fire truck. Sure wish I cold find a small V12 to put in my Model A.
  28. PackardV8
    PackardV8
    The Lincoln is a small V12. The Pierce-Arrow/Seagrave V12 would weigh about as much as a complete Model A.
    jack vines
  29. 1970malibu
    1970malibu
    from Minnesota
    The owner of Bendsten Transmissions in Ham Lake Minnesota has a '30 Model A with 1941 Seagrave V12 flathead, a 700R4 trans, suicide doors and Frank Lynn racing differential. Pretty freakin' cool too. You wouldn't believe the crowds it draws at car shows.
  30. snaptwo
    snaptwo
    Gawd what a monster ! I don't care what it's roots are--its neat ! I am glad to see there is enough interest to keep this alive. Wasn't Ab Jenkins powered by a Liberty ?
