How do I shorten a stock 52 chevy column (pics needed)
Discussion in 'The Hokey Ass Message Board' started by motoandy, Jul 7, 2012.
  1. motoandy
    motoandy
    from MB, SC
    Pretty much in the ***le. I searched and found some help, but no pics. Would like to see how some of you did it. Thanks for any and all help.
  2. 56sedandelivery
    56sedandelivery
    It "seems" to me , the 53-54 columns are already shorter, and a direct bolt-in. Plus, you get integral turn signals. The entire steering box/column ***embly needs to be swapped however. Butch/56sedandelivery.
  3. j_johnson
    j_johnson
    from Iowa
    There is a kit on the market that works pretty slick, I bought mine from CPP. Its called a column saver. You dis***emble the column, cut the outer tube to length, insert the end bushing, and then there are two locking collars, one in front and one behind the bearing in the bushing. You can make the column as short as you want.
