Features Econoline Madness Who's got one?
Discussion in 'The Hokey Ass Message Board' started by kornfedlifer, Apr 25, 2007.
  1. go-twichy
    go-twichy
    lots of old econolines will help. for awhile. then you're going to need a dodge a100.
  2. mothradeath
    mothradeath
    saved this guy from the crusher yesterday. number 2 for me. $300
  3. kgdb
    kgdb
    from The 60"s
  4. Hellfish
    Hellfish
    Yeah, a 65 6cyl Mustang radiator will run you about $100 and all you have to do is flip the mounting tabs/brackets, BUT it will only be sufficient if you're running a 144/170. It will not be enough if you have the 240 or a v8, plus the inlet/outlets will be in the wrong place.
    I ran a Mustang one on my 170 for about a year and it worked great even in 98* weather. IIRC I got it from radiatorsusa.com. Shipped to my door for about $120, I think, about 5 years ago.
  5. Hellfish
    Hellfish
    You're a glutton for punishment. :D
    Let me know if you're going to part it out. ;)
  6. Hellfish, what radiator do you run for the small block?
  7. Hellfish
    Hellfish
    It's an aluminum one. I don't know the brand. I ordered it through a hot rod shop and they moved the inlet/outlet to work with the SBF, and they may have shortened it, too.
  8. Dog427435
    Dog427435
    Saw this on Craigslist - not mine -
    Econoline truck cl***ic 1962
    4 cylinder 3 on the tree original gl***
    Price neg call 301-375-0857
  9. Dog427435
    Dog427435
    And this one -
    For Sale a 1961 Ford Econoline Pick-up
    It only has 30,000 original miles
    It is in original condition with the
    original 6 cyl. engine and 3 speed transmission
    It Does Run.....and has some rust,
    but with a little work it would make a very
    hard to find, head turning, collectible.
    only asking $2,500...... cash only..... pick-up only
    call 240-439-9067 or email john.pat2@verizon.net
    AS LONG AS THE AD IS STILL POSTED, THE TRUCK IS STILL FOR SALE....
  10. Hellfish
    Hellfish
    Very rare! :D
  11. Muttley
    Muttley
    Can anyone give me some tips for removing the kingpins? I've already got the caps that hold the zerk fittings off, do the kingpins need to come up through the top or down through the bottom?
  12. j.r. Nice
    j.r. Nice
    Need to remove the pin that locks the kingpin in place. I punched mine from the back and shoved it forward. I believe they will go either way.
    Push/press kingpin up from the bottom.
    Actually pretty easy compared to newer heavier duty stuff.
    I ***ume you know the new bushings will need to be pressed into the knuckle and reamed to fit.
    I pressed my own and took them to a frame shop to have them reamed.
    Suggestion...if you haven't ordered your kingpin set yet.....when you do, order an extra pair of bushings. I messed up one and the frame shops reamer slipped and messed up the other. Luckily I had ordered 4 by mistake.
    I bought my kit at Rock Auto and they also sell the bushings - sold in pairs.
    I made the mistake of pressing a bushing in with a socket that had too much bevel. It bloomed the end of the bushing.
    You can see the notch in the middle of the kingping where the locking pin is.
    I pushed the lower bushing out from the top using an extension and properly sized socket, and a larger "catch" socket underneath. It was quick and easy.
    The arrow opening on the bushing goes down, and make sure before you press it, that it aligns with the grease fitting.
  13. Muttley
    Muttley
    OK, I'll have another look at it and report back with my findings. I didnt notice the pin but when I was messing with it last night it was nearly dark out. It wont be going back together or in my car any time soon, I was just tearing it apart to clean it up and paint it.
  14. j.r. Nice
    j.r. Nice
    If you need a better pic showing the locking pin....lemme know. It's pretty easy to see now that it's all purdy.
  15. Muttley
    Muttley
    Yes please, that would be really helpful. My axle looks like it sat in the dirt for thirty years and was covered in old, hardend grease that I've only partially removed so far.
  16. Muttley
    Muttley
    So......I examined the axle a little closer and the one I have is a little different from yours. Mine doesnt have zerk fittings on the side, they are on the top and bottom of the kingpins with the fittings being in caps that cover both ends. Is this an Econoline axle or is this from a bigger truck? Maybe it's an earlier or later version? Here's some pictures:
  17. j.r. Nice
    j.r. Nice
    Looking at the Rock Auto catalogue, they started using your style in 1964.
    I would guess dis***embly would be the same. I'd drive the locking in forward and shove the kingpin up.
  18. yamadafacka
    yamadafacka
    took 5 inches out of the bezel and turned em vertical
  19. Chaz
    Chaz
    This is the pin that has to come out.
  20. YocumBros.
    YocumBros.
    from Raleigh NC
    Custom!
  21. Kage
    Kage
    from Delano, TN
    I just picked this one up this past weekend
  22. cruzace
    cruzace
    from tustin
    Work in progress
    Can't help but Love the Van
  23. cruzace
    cruzace
    from tustin
    Forgot some pictures
  24. nmbuellist
    nmbuellist
    This is my old pickup.I kept working on it and refining it 1970 to 1993. Built it for me to fit me. But I am done with it. I'm not going to register it or drive it anymore. I have tried to sell it here on the HAMB, but I have to admit it had a sentimental price tag on it. I'm thinking about turning it into yard art.
    Just purchased a house that has a basketball slab and backboard on it . I think I will take the hoop and bacboard off and mount a three light traffic light I have been saving on it. I'll make some stands to get the front end way up, Will have wheelstander yard art. Unless another econoline lover wants it.
      409 KB
  25. Hellfish
    Hellfish
    That's super nice! What trans are you running? Manual? I'd love to see the linkage set up
  26. SotallyTober
    SotallyTober
    from In a dream
    Dig it!
  27. KCsledz
    KCsledz
    Holy Smokes! That took some serious work. Don't know what to think yet about your custom look. Love the frenched lights but now there is so much room on the nose between them. Are you thinking of keeping it smooth or adding another custom treatment to the front?
  28. mothradeath
    mothradeath
    I contemplated doing early benz lights frenched in Damn near exactly like fiotos merc until I found out how much the sell for. I think the would totally work with the body line and look great actually coming outwards away from the nose. [​IMG]
  29. power wagon
    power wagon
    my faverite,
  30. notrod13
    notrod13
    from long beach
