401 nailhead plugs and oil?
Discussion in 'The Hokey Ass Message Board' started by maddhatter1, Jul 12, 2012.
  1. maddhatter1
    maddhatter1
    Getting ready to wrap up the last of the smalls for the nailhead. Wondering what you guys are suggesting for oil for break in and then normal runtime, and what are a good plug brand and gap size with a pertronix 2 ignition and coil. Thanks
  2. DualQuad55
    DualQuad55
    from NH
    I recommend using any of the actual break in oils sold now. We often use Comp Cams break in oil, but have had good luck with others as well. If not, make sure to use a name brand oil and a zinc additive. Usually the cam companies have recommendations as well.
    Ask the machine shop what they recommend you use for oil. Many old timers believe that an engine machined to old/loose tolerances should run heavier straight weight oil. Yet others recommend the more modern multiviscosity oils.
    Personally I run straight 40wt in my 401. But a zinc additive at every oil change is a real good idea.
    I have had good luck with Delco plugs and also Autolite plugs. Not so happy with champions in the Buick.Gaps can be funny, but typically around .035" is a good starting point.
  3. maddhatter1
    maddhatter1
    Hey thank you for the info.
  4. bangngears
    bangngears
    from ofallon mo
    Do not accidently put in long plugs,exhaust valves do not like that.
  5. hotroddon
    hotroddon
    Put in the stock heat range etc plugs that is called for in your motor, AC 44S. With the PerTronix Ignitor II, run the gap at .035" - .040" and it will be happy.
    Don from PerTronix.
  6. zman
    zman
    from Garner, NC
    I've been running straight 30 wt. for the last couple years in the 425 in my 57. Mostly Valvoline Racing with about 1/2 of a ZDDP additive for good measure. I broke the engine in about 5 years ago on LE (Lubrication Engineers) oil and used it every oil change for a few years.
  7. CWTC10
    CWTC10
    from Arab Al
    I run RotellaT for the higher zinc.
  8. zman
    zman
    from Garner, NC
    You better check that rating, you just may be fooling yourself. It's not all high zinc. And the additives for diesel vs. gas are totally different.
  9. maddhatter1
    maddhatter1
    Hey thank you all agian for the help.
  10. DualQuad55
    DualQuad55
    from NH
    True about the Rotella. They have started taking the zinc out of even the diesel blend stuff. I think for the same reasons-it hurts the cat convertors, now used on new diesels.
  11. Rattle Trap
    Rattle Trap
    Very few oils with zinc these days. I think Royal Purple still has it but you had better double check. Lots of discussions on the web about the demise of good oils.
  12. Jimmy2car
    Jimmy2car
    from No. Cal
    Keep in mind that while a lot of the zinc has been removed, other additives have been added to take it's place and do the same job.
  13. George
    George
    Some R.P is pre SM & some isn't, check your bottles.
  14. Rusty O'Toole
    Rusty O'Toole
    I have had the best luck with OEM brand plugs. In a Buick this would be AC. If you want something better than OEM, Bosch platinum are good long lasting plugs. They will probably last as long as you own it and longer.
  15. DualQuad55
    DualQuad55
    from NH
    Not to get off subject or hijack this thread, but I dont think that is necessarily correct. Most pushrod engines have gone to roller lifters which means the cams dont need the zinc to reduce wear. They have put in all sorts of other agents and detergents, but nearly all cam companies recommed break in specific oil or a zinc additive.
  16. zman
    zman
    from Garner, NC
    This is patently false. The new oil is not formulated for flat tappet cams, period. Where do people come up with this stuff?
