A tool for making holes.I know what i want but what's it called?
Discussion in 'The Hokey Ass Message Board' started by gasolinescream, Jul 13, 2012.
  1. gasolinescream
    gasolinescream
    Holes!! I've hole-sawed and cut holes in thin gauge metal but always liked that punched out look. I've seen tools that do the job, kind of 2 piece affair but haven't got a clue what they're called or where i could start looking for some. I'd love to track some down and have a play if they are not silly money.
    Any ideas please?
    Many thanks Dan:cool:
  2. Slick Willy
    Slick Willy
  3. hotroddon
    hotroddon
    They are called Knock Out Punches
  4. Westco48
    Westco48
  5. GEISTERFAHRER
    GEISTERFAHRER
  6. Chris Stapley
    Chris Stapley
    Drill bit,ha,ha... Arbour press dies are the real deal...
  7. Westco48
    Westco48
  8. hotroddon
    hotroddon
    Like I said, that is a Knock Out Punch - google it
  9. 49ratfink
    49ratfink
    the good ones are made by Greenlee, easy to find in the plumbing dept at Home Depot.
  10. GEISTERFAHRER
    GEISTERFAHRER
    Check my link but they are pricy!?!
  11. HOTRODPRIMER
    HOTRODPRIMER
    Knock out punches,,this is a image from HF,,they are cheap but if you want quality you are going to have to dig deep. HRP
  12. GEISTERFAHRER
    GEISTERFAHRER
    Never mind you are in the UK!
  13. hotroddon
    hotroddon
  14. rotorwrench
    rotorwrench
    Roper Whitney hand punch tool. It comes as a set with dies for punching small holes instead or drilling.
  15. GEISTERFAHRER
    GEISTERFAHRER
    This?
  16. Gator
    Gator
    from Statham Ga
    Got a set of those from my brother for Christmas - he swore I'd use them every day but I still haven't opened the case, other than to look at them...
  17. Over here they're known as a "Ch***is Punch" . Make sure you well oil the threads and moving faces , and they'll last a life time .
    Shrapnel :cool:
  18. Thanks for the above tip!
  19. Dane
    Dane
    from Soquel, CA
    Google "knockout punch" and you'll get a bunch of hits. I bought mine used 2 or 3 at a time off eBag to get a set of good quality used ones at a decent price. They come up all the time on eBay, so bid a decent price and sooner or later you'll win enough auctions and end up with a good selection. The used Greenlee sets are stupid expensive. The cheapos will work, but how long they last and how clean a cut is the question.
  20. hotroddon
    hotroddon
    Yep nother name for the same tool.
  21. 49ratfink
    49ratfink
    OOOH... I like the ones that come with the dimple die
  22. oj
    oj
    The best set that i have is called 'Pro-Flange' they both punch and flare (dimple) and they are made in England and, as you described, they take an allen wrench. I made an adaptor to use them in my hydraulics. I have many different punches, this set is the best set i have ever seen, excellant quality.
    I believe these were intended for the aircraft industry. The flare or dimple in the automotive industry has a well defined edge and raises the panel at an angle. The aircraft flare is much more defined and kinda rolls the outer edge, it don't quite get to 90deg but it is greater than the automotive one. If you go to the mittler bros web site i believe they have a comparison.
  23. Rusty O'Toole
    Rusty O'Toole
    Have heard them called boiler cutters too.
  24. gasolinescream
    gasolinescream
    Thank you all for the response. Wow:eek: they aren't cheap but sure do make a nice clean, rolled edge, which i really like.
    I don't mind shelling out decent money for tools as long as they'll get used and as i'm planning to do quite a few various size holes i'd rather get a quality tool to use.
    OJ thanks for the info and ref the allen key. Thought i was going mad, I remember where i used them now, it was when i used to fit sunroofs.
    I'll be keeping my feelers out for some soon, thanks again with the info HAMB'ers.
    :cool:
  25. Phil1934
    Phil1934
  26. dan c
    dan c
    we always called it a die--good for making a larger hole
  27. Ford blue blood
    Ford blue blood
    They are ch***is punch in the electronics field, I have a set, both round and square. Love them!
  28. Thats what I always called them in SoCal, ch***is punch ... I think the names comes from the days of making radio ch***is' and the necessary holes.
  29. bad4dr
    bad4dr
    We called them slugbusters. They work great.
