How would you remove a Crappy paint job?
Discussion in 'The Hokey Ass Message Board' started by OoltewahSpeedShop, Jun 15, 2012.
  1. OoltewahSpeedShop
    OoltewahSpeedShop
    If you had a car with no rust thru that someone put a quick, **** paint job over the original paint.... How would you remove the said paint and not damage the original paint underneath?
    I don't want to remove the paint back to metal, just the last repaint.
    Anybody done something like this?
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Wet sand it down to the original color
  3. BEAR
    BEAR
    you can try EZ OFF... thats what we use to take ****py pinstriping let it set foe 2 to 5 mins and wash it off .. try it in a little spot first
  4. henry29
    henry29
  5. 49ratfink
    49ratfink
    I'd say 600 grit wet sand paper. sand until you get close, then use 1000[
  6. OoltewahSpeedShop
    OoltewahSpeedShop
  7. mashed
    mashed
    from 4077th
  8. A good media blaster can take paint off a layer at a time.
  9. metlmunchr
    metlmunchr
    If its one of those paint jobs where the previous surface wasn't thoroughly cleaned of all wax and grease then a pressure washer will often take it right off, especially if its enamel.
    Bought a backhoe a few years ago with a god awful mess of a paint job that appeared to be in pretty good shape otherwise. Figured a repaint would allow me to double my money on it. Told my son to pressure wash it before we started sanding to smooth up the paint. I go out to check about 3 hours later to see if he's gone to sleep or something, and find he's stripped about 90% of the paint back to original with the pressure washer. Took him a couple more hours to finish all the nooks and crannies, but when he finished there wasn't a speck of the **** paint job left anywhere, and none of the original paint came off in the process.
  10. Badillac56
    Badillac56
    There is no subs***ute for sand paper and elbow grease. Beware of the strippers.
  11. What I may try is a soft rag and some MEK. If the ****py paint is real ****py paint ans the paint undernieth is good and solid the MEK should lift it and not reall hurt the good paint. We use MEK to remove pinstripes all the time.
    be worth a try, maybe try it on a hard to see spot first.
  12. OoltewahSpeedShop
    OoltewahSpeedShop
    Looks like they just sprayed a half *** semi gloss black over the original Henry black. The MEK didn't have much effect. 600 paper knocked it down pretty quick. Just the high spots.
    Drove it to our local Sonic Cruise In last night.
    Here's the "So Far".....
  13. gassercrazy41
    gassercrazy41
    Just wet sand with some 600 then go down to 1000 I'd say
    Sent from my iPhone using TJJ app
  14. OoltewahSpeedShop
    OoltewahSpeedShop
    Once getting thru the ****ty repaint, I see why they did it. Theres not much original paint left and bare metal in alot of spots. Any suggestions on a clear or something to protect the metal?
    I'm not ready to do a full paint job right now, and don't want any metal damage while I'm enjoying it as is.
  15. 57JoeFoMoPar
    57JoeFoMoPar
    Just spot prime it and roll with it. If you're going to paint it, it'll need to come down to bare steel eventually.
  16. indyjps
    indyjps
    agree, spot prime it or use semi gloss black, scotch brite the whole car to even it out.
  17. OoltewahSpeedShop
    OoltewahSpeedShop
    Oh yeah, It will definitely have to go back to bare metal to get the SLICK black. Just trying to preserve it for a while. I've been driving it to work all week, total time warp..... Love it.
  18. carcrazyjohn
    carcrazyjohn
    from trevose pa
    400 grit and then work finer
  19. zman
    zman
    from Garner, NC
    Never have had good luck trying to strip just the top layer off. Good luck, though I'd be more inclined to scuff it and give it a quick cheap single stage job.
  20. enloe
    enloe
    from east , tn.
    Cool car will we see it friday night??
  21. OoltewahSpeedShop
    OoltewahSpeedShop
    Yeah, I think one of our car club members is gonna drive it over. It's been my daily driver for the last couple of weeks. Great car.
  22. adam401
    adam401
    :eek:Aircooled VW sites are filled with threads on this topic. Original paint is king on early VWs. I have heard all the different methiods but my own experience has shown me that:
    Cut a the top layer by hand with 220 wet. Just knock off the shine.
    You don't want to expose the layer underneath.
    Then 400 wet until the substate (og paint) comes though. I then use 600 but some might say that is too abrasive.
    I only sand until 70% of the paint is removed (what is left looks like a milky, streaky layer).
    Then I use Ajax with a geen scotchbrite pad until the original paint is exposed.
    To buff it out I have used hand compound and then wax because I am not skilled with a buffer and the paint thats remaining will be even easier to **** up than a fresh paint job.
    You will probably end up blending a few areas where repairs have been made. CLR and scotchbrite works well on any surface rust they may have painted over.
    Good luck, I have done this twice and it takes for ****ing ever. Im thinking about doing it to a 41 buick fastback next
  23. OoltewahSpeedShop
    OoltewahSpeedShop
    Well, I've been on vacation for the last 10 days. While most people would be doing nothing but enjoying the beach... I've been thinking of the best way to attack this paint.
    After taking all suggestions to heart, I chose to strip the top layer with EZ Off oven cleaner. Then work on the problem areas with Green Scotch Brite pads and CLR.
    The EZ Off cut that **** like ****er..... :D The green pads are WAY abrasive, so I took it easy. The grey pads might have worked better (in my situation), but I didn't have any new ones. After ruffing up the RR fender for absolutely no reason, I put the pad down until all the paint was back to the original.
    The ruffed up area will slick back up pretty easy, but it scared me when it dried.
    Here's a few "So Far" pics. As you can see, that Henry black is alive and well with some shine still left in it. A couple of the pics show where I stopped stripping, and the difference between the two.
    I went VERY slow and only did small spots so I wouldn't damage the original paint.
    What do you guys think so far?
  24. Diavolo
    Diavolo
  25. OoltewahSpeedShop
    OoltewahSpeedShop
    A few more.
  26. dirt slinger
    dirt slinger
    I sure do like that car! Wish my dad had kept it. Good thing is it went to a good home.
  27. bobby_Socks
    bobby_Socks
    from ǑǃƕǑ
  28. 40FordGuy
    40FordGuy
    Spot prime....Find primer in a color that's close to the remaining factory paint and go with it. It has to look better than the sh**** job someone did.......
    4TTRUK
  29. OoltewahSpeedShop
    OoltewahSpeedShop
    Well... The factory color is Henry Black. Seems like the factory primer color is red oxide. Looks like there is some grey primer up around the grill area. Can't imagine that isn't original, because everything else is...... So, should be.
  30. OoltewahSpeedShop
    OoltewahSpeedShop
    Here's a few more pics from this week. These are from a really nice river park on the way home from work. I still have a little more work to do on the doors, trunk and roof but it's getting there. It looks to have had some sort of logo on the doors (same kind of spot on both doors). Hopefully I can save it.
