I am using f100 brakes on my sedan and the grease cups are very in the way is there any one who has gotten rid of the grease cup and used a regular pound in seal instead thanks guys
I have been running that same set up with out the cups for the last 30 years(on a number of cars). The cups were there for the old rawhide seals . Once they started to leak(and the did), the cups kept the grease off the brake shoes. With the new seals you'll be good to go for 100K miles.
Baron thanks again man I searched everywhere I was just going to shoot down to the parts house and ask
i did not know that as long as i dont have to use the cup im golden and baron im ***uming these will work on the 42 to 48 spindles
the Napa seal #15214 is for a shaft that is 1.500" in diameter , the part where the seal rides on an old ford spindle is 1.562"......but i'm sure it will work fine national 473440 is also for a 1.500" shaft , so is 450461 i use national # 473441 which is for a 1.562 shaft
