Projects I found a power unit with a 59AB flathead in it, let's see some other power units!
Discussion in 'The Hokey Ass Message Board' started by INLAW MODEL A, Mar 21, 2010.
  1. Dale Fairfax
    Dale Fairfax
    Pat: Any chance of finding out if there is a governor on that water pump engine? And if so, what kind of R.P.M. is it set for?
  2. bryna
    bryna
    from Iowa
    Here I am putting to good use our Schramm Model 60 complete with Schramm Air Hammer during construction of my shop.
    Basically a Ford Flathead V-8 where 4 run the engine and 4 make air.
    We rebuilt it a few years ago and use it mainly for sandblasting and occasional other uses...
    Dwight schneider likes this.
  3. Looks like maybe the point was more weight in front to lift more @ rear. Probably just hand oiled the crank bearings since RPM was so low because the only time it turned was in transit to & from lift area The whole truck has been lightened - not even gl***.
    Chuck
  4. six pack to go
    six pack to go
    from new jersey
    No overheating issues??
  5. designs that work
    designs that work
    No pictures of the wind machine that mine came out of. Farmer let us use his torch and forklift. Came with a four speed trans that had the separate bell housing needed for a t5 conversion. All which found a home in my modified.
