What's size tires on your AD Chevy?
Discussion in 'The Hokey Ass Message Board' started by adamshumard, Jul 18, 2012.
  1. adamshumard
    adamshumard
    What size radial tires do you run on your lowered AD Chevy? Please include pics. I'd prefer ones on stock 16 inch wheels.
  2. GirardsSpeedShop47
    GirardsSpeedShop47
    You Might try the AD Group but if I remember there is not much on the subject.
  3. GirardsSpeedShop47
    GirardsSpeedShop47
    I am running 15" wheels thats why I didn't share.
  4. and I have 14's and 15's so no info for you unless facts like the 15's with the tires I run raise the truck 2 1/2 inches over the 14's
  5. adamshumard
    adamshumard
    Other sizes would be ok, I can figure tire diameter and convert to comparable 16.
  6. simplestone
    simplestone
    I'm going to run stock 16 inch wheels but haven't bought tires yet. Interested in this also...
  7. Mr48chev
    I'm running 205 60 14 on the front and 255 60 15 on the back right now but will go to 215 75 15 all around when it goes back together as I'm going from the 80's hot rod truck look to a low but fairly level custom look this time.
    I think this tire is a 215 15.
    With the 205 14 on the front
    195 or 205 14 on the front and N 50 14 on the rear in this photo.
  8. EnragedHawk
    EnragedHawk
    from Waco, TX
    I'm running 235/75/15's. That puts them at about 29" in height and 9.25" in width.
    Pardon the O/T wheel, I'm working on it...
  9. GirardsSpeedShop47
    GirardsSpeedShop47
    Well I just put some Kelly 225/75r15's on the back this week due to some rubbing on the inHer fender well. Put them on my 7" wide Cragar and I think they look great minimal side wall hanging over the rim.
  10. GirardsSpeedShop47
    GirardsSpeedShop47
  11. butterboy
    butterboy
    215-60-16 on stock rims all around.
  12. 54EARL
    54EARL
    from Idaho
    I'm running the same as McKee.
  13. waldo53
    waldo53
    from ID
    These are 215/75R-15's on later 15" truck rims.
      171.3 KB
  14. adamshumard
    adamshumard
    Thanks for all the responses, really helping me decide.
  15. adamshumard
    adamshumard
    Any other shots of your truck?
  16. GirardsSpeedShop47
    GirardsSpeedShop47
    Waldo where did you get your rims? Also what back spacing and bolt pattern? Thank You
  17. shadams
    shadams
    I just bought 215/65-15 fronts and 255/70-15 rears. The rears look m***ive on 8" rims. Trukcs not together yet but the wheels are bolted on...
  18. waldo53
    waldo53
    from ID
    The rims are mid to late 60's 6-hole truck wheels, (same pattern as the stock AD wheels) 4" backspace which is a bit much for the front (puts the tire too close to the tie rod ends) so I run 1" spacers on the front. They are perfect for the back since I've got a '68 truck rear end in there with 3:08 gears and it's a tad wider than the stock rear end.
