Hot Rods 32 Pickup Build
Discussion in 'The Hokey Ass Message Board' started by 2935ford, Jul 12, 2012.
  1. 2935ford
    2935ford
    Everyone remembers this stage, right?
    Now the "clean" side of the build begins.
    It took 12 1/2 25kg bags of sand to blast the rust away!
    Left quite a sand box not fit to play in.
      242.6 KB
      450.5 KB
  2. irondoctor
    irondoctor
    from Newton, KS
    keep the pictures coming along the way!
  3. 2935ford
    2935ford
  4. 2935ford
    2935ford
    A little more done with mock up today.
    Anyone know if there is a difference in "A" hairpins vs '32 hairpins?
    I am tempted to use this '34 rear axle and shorten the tube and driveshaft.
    Maybe a little more sturdy than the stock '32?
      273.3 KB
      256.6 KB
  5. 2935ford
    2935ford
    I got a little more work done today. Mocked up my 276ci 59A flatty with the '35 top loader and set in between the rails.
    Waiting now on the rad I ordered from Superior so I can set the front mounts. I can then bolt the engine in and that will give me ride height to mount the hairpins on the frame.
    To bad my original wishbone was in better shape, I would simply use it in it's stock location to give me a no fuss front end. Just to pricey to buy another and I already have the hairpins.
  6. KustomCars
    KustomCars
    from Minnesota
  7. 2935ford
    2935ford
    Thanks KustomCars....this is a fun build.
  8. Nice! I will watch this one.
  9. Montana32
    Montana32
    Nice pickup build!
  10. 2935ford
    2935ford
    FLOWMEISTER, I like your COE!
  11. 2935ford
    2935ford
    Montana32, thanks.
    Cool '32 sedan you have there!
  12. Roger53
    Roger53
    Please keep us posted I my self picked up a 33 ford pick up cab with a bunch of parts to start a rod build. Will be doing it poor boy 1950's type.As maine was a place of little money. Roger
  13. 2935ford
    2935ford
    Will do Roger53.
  14. timwhit
    timwhit
    Naturally I am interested....keep them pics comin'..Tim
  15. 2935ford
    2935ford
    I'll probably be looking for some help along the way and this is the best place to get it for sure!
  16. 2935ford
    2935ford
    I'll digress for a momnet. This is what I am starting with. A '32 Model B 4 banger. She looks much better than she really is. She's had a hard life.
    The A pillar drivers side below the roof is completely rusted through. The 4 banger has seen it's day. The wishbone/axle/right rear radius rod have had accident damage. The brake system is frozen up with rust. The frame needed some real scrubbing. Still and all...there is plenty to work with.
    I considered a stock restore but finding what I found mentioned above and having everything already at hand to upgrade to a flatty V8 w/hydraulic brakes won out.
  17. 2935ford
    2935ford
    My plan includes making it a safe vehicle once more to drive and enjoy. I will fix the A pillar but the rest of the sheet metal and patina'd paint stays. I'll run a 4" drop aaxle and Posie reverse eye front spring and hairpins. F1 shock mounts, disc up front drum rear on the stock '32 rear end. Steelies with big n littles. Convert to 12v.
  18. 2935ford
    2935ford
    Well, a little more work today.
    I took a scraper and wire brush at the end of my electric drill and cleaned up the stock steering box. Mounted it to the rail. It feels pretty tight.
    I now need to bolt the left exhaust header and see if it works. The motor is sittng a little tilted to the drivers side right now.
    It appears the '35 shift lever may be to long as it comes in contact with the steering wheel. I may have to use a single low bend lever that is also shorter like the stock shift lever.
  19. 2935ford
    2935ford
    Sorry, here's the box when I pulled it.
  20. lowsquire
    lowsquire
    from Austin, TX
    good to see another 32 pick up getting built!
    you can cheaply build a new wishbone out of the original ends, and a later set of rear bones,if you can weld.
    you should really strip that steering box, and at least clean eighty years of heardened shitty grease out, it will need at least bearings.."feels pretty tight" well, that doesnt really mean its good, just that its tight.
    why not rebuild it while its out? the truck will drive much better.
  21. 2935ford
    2935ford
    Lowsquire, thank you.
    Here's my wishbone. Apparently the accident it had many years back, broke/cracked both the drivers side wishbone and the rear right radius rod along with bending the axle.
    The fix then was to weld a plate to the wishbone. It appears to be straight but....it sure looks butt ugly. Is it safe.....probably can I use it as is....probably.....do I want to because of it's looks...no!
    I need to remove it from the axle....measrue it for correctness. I guess I could grind on it and smooth it some? I'm pretty sure this fix was done with the wishbone still under the car.
    I have another good set of radius rods, so that is no longer an issue.
    Unfortunately, I don't weld. Finding someone who does has been difficult here. I may have a lead on a person who does and I will follow it out.
    The steering box is only for mockup right now. Yes, thank you, I'm going to go through the box. Only mentioned that as I have had many boxes with my cars that did not feel as good as this one being as old as it is. There is also some dents at the bottom of the steering tube that I want to fix also.
  22. 2935ford
    2935ford
    Sorry, the pics didn't attach.
    Try this again.
  23. 2935ford
    2935ford
    Ok then. I have tried attaching a stock 59A exhaust header on the drivers side but there is interference with the stock steering box.
    If I raise the engine some it will bolt on but is right up against the box but still to close for a proper fit.
    Suggestions?
      454.6 KB
      267.1 KB
  24. 2935ford
    2935ford
    bad wishbone
    a few more pics of it.
    should I:
    replace it (lots of money)
    weld in a new section
    grind it down
    use it as is
    suggestions/comments
  25. cadillacoffin
    cadillacoffin
  26. Itchy-Pit
    Itchy-Pit
  27. RatPin
    RatPin
    You mean "clean the wallet" stage...
  28. 2935ford
    2935ford
    Yup, that to!
  29. 2935ford
    2935ford
  30. 2935ford
    2935ford
    Bits and pieces.
    I now have my blaster box up and running once more so I went at it with a few pieces.
    A little paint and good as new!
